"The Wire" Ultra-High Performance Headphone Amplifier - PCB's - Page 173 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 4th December 2012, 07:26 AM   #1721
Stixx is offline Stixx  Germany
Stixx's Avatar
Sorry for repeatedly posting in the wrong thread since we have the conglomerate build thread… but here goes.
Last weekend I also took the advice of OPC and qusp and went to improve the wiring on my “Wire”. So I managed to twist the wires from the mini XLR to the board at least twice (I was afraid of actually breaking contacts off the mini XLR…) and fabricated a new umbilical to the psu using bigger gauge wire and braiding them like my daughters blonde hair .
The result is interesting… I am under the impression that the treble region changed… to the better.
I am not sure whether this is due to the improved wiring or other… I also seem to observe that the amp is so transparent that I can feel (hear) the influence of mains pollution. In the evening “The Wire” simply sounds better. Time to think of a mains filter or resurrecting the isolation transformer that is sitting in a corner of the room. ..?
Did I say that this amp is utterly transparent? Oh yes… it brings you very close to the music with fantastic resolution and a big open soundstage but also merciless reveals any flaws in the recording , hiss of the recording gear and so on.
Compared to my favourite tube amp the tonal balance is a tad leaner (on Sennheiser HD800) but it pairs very well with my Sennheiser HD650 that gives male voices a bit more chest. Sound is full and has beautiful impact (--> PRAT although I don’t have a clue what it actually means… maybe you guys can enlighten me). One of my test tracks lately is “Ton sur Ton” on Marc Johnsons ‘Shades of Jade’… what can I ask more?
Old 4th December 2012, 09:23 AM   #1722
Talking Added PRAT value
Pace, Rhythm, Attack & Timing apparently ... but if you think of it from a musicians point of view, pace, rhythm & timing of a piece of music are pretty much the same thing. From an amps point of view, these terms describe it's ability to convey the feel of the music to the listener, ideally giving correct delineation of each individual part without hiding or adding to it artificially ...
I find the album Tourist History by Two Door Cinema Club to be have a lot of immediacy about it, with The Wire it feels like your being draged along by the scruff of your neck with hardly a chance to catch your breath. The same album played through my A/V system lacks the drive it had with the Wire. Details are lost due to various reasons and different aspects of the music can be heard giving it a more mellow feeling...
A lot of personal preference is involved...
Paul
Listening with Gusto!
Old 6th December 2012, 07:08 AM   #1723
Stixx's Avatar
Paul,
thank you for the heads up on PRAT... I actually knew what it meant but didn't know the individual "components" of the abbreviation
Old 6th December 2012, 11:26 AM   #1724
LOL... no problem, wasn't to sure so went for overkill
I always find these threads a great source of usefull info. After the talk on wiring I've gone back to my own and implemented some of the suggestions. Already using sheilded twisted pairs for the audio signal, but hadn't done anything with the transformers wires... so shortend & twisted 'em, can't say I can here any difference, it was already silent at full folume with all the components connected and turned on.
One very happy camper...
Old 6th December 2012, 09:44 PM   #1725
N Brock is offline N Brock  United States
N Brock's Avatar
It's been a year and a half since I completed the Wire headphone amp. I love it but now that I live in the city (seven stories up) I get radio noise.
I know the wiring could be optimized a bit (a la Owen's post a couple pages back). I don't get any 60hz hum, just scratchy radio ads and trending songs.
Here is my layout as it stands.
The chassis is connected direct to mains ground (screw near the back of the divider). I have tried both connecting the PCB ground to the chassis and leaving it floating but I didn't notice a difference in noise.
I'm using a USB dac + B1 for my pre, my RCAs are about 12" long.
I will definitely twist the signal pair but I doubt that will fix all my problems. Do I need to shield my RCA cables? My headphone cable? I can reduce or increase the interference by moving the headphone cable around. I never have this issue with my speakers connected to the same source (I know it's not the best test b/c of different sensitivity).
Any advice?
-Nelson
Old 7th December 2012, 08:35 AM   #1726
qusp is offline qusp  Australia
qusp's Avatar
twisting the input wiring is the single biggest thing you can do, it always baffles me why people dont do it... twist ALL signal and power pairs; if you havent done that, that is why you are picking up noise.
its a DC coupled wideband amplifier, without twisting the input and output wiring you are turning the input connections and the headphones and headphone voice-coil into an aerial, which is why iut changes when you move the headphone cable around.
Old 31st December 2012, 10:49 PM   #1727
Never mind....I see the boards are no longer available...posted a WTB...
Old 1st January 2013, 04:21 AM   #1728
qusp's Avatar
lucky =)
Old 8th January 2013, 03:29 AM   #1729
merlin2069er's Avatar
Send a message via MSN to merlin2069er
I'm almost finished with "the wire" headphone amp. I just have to wire up the jack and power switch.
I have a led rocker switch, that I might swap out. It requires 12vdc to power up the led when it's switched on (I believe). I guess I can't wire it directly to the incoming ac.
What are the trim pots on amp for again? I'm certain I've already set them and forgot about them.
Old 8th January 2013, 04:09 AM   #1730
There are no trimmers on my amp boards, they're on the PSU
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 03:35 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 06:12 PM
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 46 6th October 2008 03:47 AM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 09:28 AM
My A.N.T. "Amber" headphone amplifier x-pro Headphone Systems 8 1st October 2007 08:47 AM
Copyright ©1999-2017 diyAudio
