Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 3rd December 2012, 08:22 PM   #1711
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
but will it blend?
Old 3rd December 2012, 08:25 PM   #1712
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Originally Posted by opc View Post
It's probably easier to buy the non-latched version of that connector...
Just a suggestion
Thanks! That will be the 3rd headphone jack for this amp.
Old 3rd December 2012, 08:42 PM   #1713
opc is offline opc  Canada
opc's Avatar
Originally Posted by hochopeper View Post
That's a wild, outside of the box, thought Owen. You beat me to it ...
I'm well known for my wild crazy ideas
Originally Posted by qusp View Post
but will it blend?
The 5mm front panel or the Neutrik jack? My money is on the latter...
Plan twice buy once! It's cheaper than planning naught and buying thrice.
Besides, if you put the locking connector to the blender test, then it won't really be a waste now will it?
Owen
Old 3rd December 2012, 08:49 PM   #1714
Can you say Audio?
How do you think DIY'ers end up with such a good 'stock' of parts for a future project? :-)
Old 3rd December 2012, 08:57 PM   #1715
Well I've got the non latching Neutrik jack as well. I'll just need a thinner front panel.
Where do I get a front panel? I can drill out the holes for the jack, switch and pot.
Old 3rd December 2012, 09:01 PM   #1716
Can you say Audio?
Sounds like a job for Front Panel Express:*Front Panel Design Software and CAD Conversion Service
Old 3rd December 2012, 09:41 PM   #1717
The non latching jacks like this - NMJ6HFD2-AU - Neutrik - should easily do 5mm ??
Have you already made a hole for the D socket? Why couldn't you mount the D socket anyway? I'm confused as to why this is an issue that needs a whole new front panel ...
Old 3rd December 2012, 09:44 PM   #1718
I've already drilled out a rather huge hole about 24mm to fit the locking neutrik jack (but it wouldn't quite fit without removing the screw).
I'll get someone to print the panel out of plastic.
Old 3rd December 2012, 09:45 PM   #1719
qusp's Avatar
can you not arrange for the 5mm panel to be milled to accept the jack?
opc: yes neutrik jack lol, I suppose given a large enough blender the 5mm front panel may blend.
too slow
Old 3rd December 2012, 09:50 PM   #1720
Ahhh I think I see the problem now.
I wonder if its a job for a file and a bit of elbow grease?
Another option is to make the 24 mm hole a touch larger and get a gasket from neutrik, not as neat but might get the job done.
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 03:35 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 06:12 PM
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 46 6th October 2008 03:47 AM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 09:28 AM
My A.N.T. "Amber" headphone amplifier x-pro Headphone Systems 8 1st October 2007 08:47 AM
Copyright ©1999-2013 diyAudio
