| Headphone Systems Everything to do with Headphones |
#1451 | |
Thanks for the info. And for the 2 SE-SE pcb's! Looking forward to build and use it. Will update on progress to help others! |
#1452 |
Sometimes a square peg fits a round hole just fine
he, like several of us do not use a pot at all, we use the inbuilt digital attenuator in the dac (several dacs allow this including es9018, es9012, wolfston wm8740/1 etc)
#1453 | |
All modern gear should be able to drive a 10k load without issue, even tube gear. If it cannot do that, I would step out on a limb and say it's probably not worth using. Regards, Owen |
#1454 |
yep 10k is a good median value, but i would avoid ebay fake dacts and buy the ELMA MV series stepped unit with the thin films. in fact it appears they make the dacts for dact under license, so cheaper to go direct. is this for a portable unit? not many high quality attenuators that will fit in a small enough case for portable.
#1456 |
Sorry for the question, but will the original layouts be provided? Or at least separate images of each PCB plane? (Not that it's much different..) One could then try to make his own board.
#1457 |
I have a good question that might be interesting to many people here.
Can BAL-SE and BAL-BAL versions of The Wire be used or adapted to work as an I/V stage for DAC like AKD12P from Acko? And if yes then can someone provide an implementation scheme on how to do this. And the second question can this setup perform two roles and serve as I/V output stage and as a headphone amplifier? Maybe this idea is not first around here, but I sure think it can be very useful. I found that opa1632 is used in Anedio D1 based on es9018 and in TwistedPear The IVY III Balanced Linestage. P.S. Very little familiar with diy but as far as I know, some preamps can serve as headphone amps. Maybe these "Wire" gems can do more than just drive the headphones. Anyhow if someone have an idea of similar kind I would like to hear it. Last edited by TiEx; 3rd March 2012 at 12:18 PM. |
#1458 |
TiEX: I guess you havent been reading my posts, i'm not going to do a guide, but yes its possible, though for best performance with es9018/2 you shouldnt populate the input resistors and lower the feedback resistors to 680R. no its not the first time someone has mentioned it, ive been talking about it since the beginning of the thread and even posted pictures and a description in the build thread I started
Nevod, i'm not opc, but i'm saying no and if you have a diy process to make your own 3-4 layer pcbs i'm all ears. it is unreasonable to expect that everyone on this site give away their intellectual property for free |
#1460 |
nope, this is only when using the amp as combo IV stage/headphone amp and particularly with sabre if you want to remain as much in 'current mode' output as possible. the input resistor does not exists in the sabre or for that matter acko or TP IV schema and RG would be 680R for unity gain. this way you basically end up with a buffered current mode sabre IV stage, which also drives headphones rather well
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| Serg69 |
| Which Pass Aleph diy board for "no-cost-object" headphone amplifier? | Hammerklavier | Headphone Systems | 43 | 7th August 2010 03:35 PM |
| Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" | kipman725 | Headphone Systems | 4 | 17th August 2009 06:12 PM |
| Project 11.1 from Slone "High-Power Amplifier" Book | Karl71 | Solid State | 46 | 6th October 2008 03:47 AM |
| The "Freebird" ultra clean ultra simple preamp design | Russ White | Chip Amps | 87 | 11th August 2008 09:28 AM |
| My A.N.T. "Amber" headphone amplifier | x-pro | Headphone Systems | 8 | 1st October 2007 08:47 AM |
| Page generated in 0.13649 seconds (75.03% PHP - 24.97% MySQL) with 11 queries |
