Headphone Systems Everything to do with Headphones
Best type of wire for re-cabling AKG 701's .. anyone do this?
Old 26th November 2011, 05:31 AM   #11
qusp is offline qusp  Australia
qusp's Avatar
hehe yeah as someone who recables headphones for a living, ive worked with starquad. personally i only ever use it if someone specifically asks for it and even then i discourage it. right there you have a crosstalk problem, starquad was never designed for stereo, its a microphone cable and for that it works very well. if you must go for a prefab cable and a shielded one, try to ensure its got 2 individually shielded twisted pairs.
Old 15th December 2011, 03:19 AM   #12
jschristian44 is offline jschristian44
Here is what I gathered from using different cables over the years and help from other people:
Canare Starquad Cable - Good cheap cable that will add better sound than the cheap stock cable, but not that much better.
Mogami 2534 Cable - Adds warmth and better sound quality to your phones. I think this would be an excellent match for the K701 since they are already bright and using this will increase details as well as give them that extra quality.
Silver Teflon Cable - I use this for a lot of my headphone re-cabling. It adds a little brightness to the signature, but I think it also adds the most details and quality to the music better. If you can find a way to tune down the brightness on the K701 you could use this. It's also as cheap as the Starquad. I am using this to re-cable my custom T50RP in wooden cups as well as other phones like IEMs.
Old 15th December 2011, 07:47 AM   #13
qusp's Avatar
and if you got it fro Johns 'silver' wire shop, its also silver plated copper, not silver. he doesnt have a single product that is silver wire and tbh assuming you are indeed talking about him, dont even think about doing your iems, the microphony is over the top
Old 15th December 2011, 10:29 AM   #14
jtktam is offline jtktam  Canada
Originally Posted by qusp View Post
i actually found their cable to be a piece of crap, but hey what do i know
qusp.. can you tell me what you mean by "dont even think about doing your iems, the microphony is over the top"?
-joe
Old 15th December 2011, 10:36 AM   #15
qusp's Avatar
iem cables are particularly prone to microphony, ie. vibrations against clothing, buttons, te cable itself, movements etc are transmitted up the cable and cause noise in your ears, iems are the worst because they are directly coupled to your ears and they are sealed (think eating with iems) his wire is one of the worst, if not THE worst wire i have ever encountered due to the rather stiff and thick teflon coating. its bad enough on headphones, iems would be nuts.
Old 15th December 2011, 10:57 AM   #16
I am using his wires on my q701 and i don't see that issue.. let me go back to the stock cable..
qusp.. what would you recommend for my akg q701?
-joe
Old 15th December 2011, 11:51 AM   #17
qusp's Avatar
yeah well thats not really much of a parallel is it? the q701 is a full size, fully open back headphone, provided you sleeve the wire its probably not going to be bad. the problem arises mostly with closed headphones, or worst case scenario is IEMs as they are sealed and you have bone conduction as well.
i like copper with the AKGs, i would use something like TWCu, but that might be above your budget.
Old 15th December 2011, 01:11 PM   #18
thanks for the advice..
-joe
Old 15th December 2011, 08:39 PM   #19
I am talking about John's wire. I forgot it was silver plated copper, it's still better than copper I think. Anyways, I already re-cabled a set of RE-0's that were torn apart with it and they worked fine. The microphony wasn't that bad at all. Nothing worse than stock. What I did notice is that they were very harshly bright and the highs were piercing. This is what I think will be the exact same thing if you try to use wire like this with the K701. They will be almost unbearable to listen to and think someone is piercing your ears with a needle inside. So I would suggest using the Mogami 2534. A ton of people use it to re-cable their headphones like the K701. It's high quality and doesn't cost much at all. Under $20 for a 10 foot long cable. It is also quite heavy and thick. I think the starquad is much light and probably not that different in overall sound quality. Mogami is just made better.
Old 2nd October 2012, 07:46 AM   #20
sszorin is offline sszorin  Canada
Default recabling ak 701
-joe
This is 10 month late but if it helps, the best option is OCC copper. A manufacturer is right in Toronto.
Audio Sensibility - OCC Copper and OCC Silver Audio Cables
Page Title
Page Title
You can buy wires and adapt them for headphones or email them if they would make the cable.
Best type of wire for re-cabling AKG 701's .. anyone do this?Hide this!Advertise here!
Power supply cabling rsumperl Parts 2 1st September 2010 05:51 PM
Need your ideas for ES headphone cabling j beede Planars & Exotics 3 30th January 2008 07:27 PM
Power supply cabling smithy666 Solid State 1 24th April 2007 01:22 AM
Which cabling to use? matthew2456 Tubes / Valves 9 11th August 2006 09:42 PM
Appropiate cabling quality & Regulators eeka chu Tubes / Valves 30 17th February 2004 02:41 PM
Copyright ©1999-2017 diyAudio
