Headphone Systems Everything to do with Headphones
JLH Class A headphone amplifier
Old 21st April 2016, 12:17 PM   #91
lisoformio is offline lisoformio  Italy
lisoformio's Avatar
Is the schematic for this psu available?
Old 24th April 2016, 03:10 PM   #92
jamesfeline is offline jamesfeline  United Kingdom
jamesfeline's Avatar
Hello .. yes I have this, I will email to you .. regards
Old 27th April 2016, 11:19 AM   #93
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
I just put it in a wooden box with a toroidal trafo and RCA inputs. Still waiting for 1/4in stereo jack to install. In meantime I had a listen with temporary 3.5mm jack on MDRV6's. Wow the sound is incredible. Deep deep bass and soaring clear highs.
Needed the box to use this at work. Most of my projects don't have a real box - I found that little craft boxes like this are convenient and inexpensive. This one was $5 from Michaels.
Old 7th May 2016, 12:41 PM   #94
Looks like a nice little build .. well done, does it sound Ok ?
Old 7th May 2016, 12:52 PM   #95
Got Foam?
xrk971's Avatar
This little amp works like a charm - well beyond the $20 cost of the board, $11 for toroidal transformer, $5 for misc RCA input and TRS stereo out jack. Btw, I am using the GLS Audio 1/4in stereo TRS jacks and they are really nice. All metal high quality with a decisive click. They look bullet proof and will last forever.
One issue I have and I think it's because I don't have the main board connected to earth ground is that when the volume pot is not on full output there is hum. So I need to fix that (also for safety).
Sound wise it's a fantastic amp and I am looking forward to trying some better headphones than my 20yr old Sony's on them.
I am thinking of building my own headphones with a nice Visaton B80 full range driver. Will 3D print the yoke and headband. Ordered some foam cushioned earpads alread. There is a thread for that in Fullrange forum.
Old 7th May 2016, 01:46 PM   #96
great .. thanks for the update ..
Old 14th May 2016, 08:41 AM   #97
R.I.P.
Originally Posted by xrk971 View Post
..................One issue I have and I think it's because I don't have the main board connected to earth ground is that when the volume pot is not on full output there is hum. So I need to fix that (also for safety). .......................
If it's all enclosed and there are no metal/conductive parts to touch, then Safety is much less of an issue. Just use a close rated fuse. Make sure any equipment you connect it to, also has a close rated fuse.
Try to use twisted pairs for more of your wiring.
Connect any non-audio internal metal work to a common ground reference.
regards Andrew T.
Old 24th November 2017, 04:23 PM   #98
Originally Posted by AndrewT View Post
James,
can you attach the pics missing from post1?
Hello sorry for the delay .. please find a few pics from the 1st posts .. this unit has long gone to a happy owner
Old 24th November 2017, 04:25 PM   #99
I have a new unit in construction currently .. but still work in progress .. so will update when I have more to show
regards
Old 14th February 2018, 03:43 PM   #100
Hello ... just completed the main head phone amplifier PCB preparation .. nice and clean etc.
just a few pics before construction
JLH Class A headphone amplifierHide this!Advertise here!
JLH 10 Watt class A amplifier tschrama Solid State 4782 Today 08:56 PM
JLH headphone amplifier steveh49 Headphone Systems 8 14th May 2014 03:31 PM
JLH 10 Watt class A amplifier #2 DomKo Solid State 8 30th October 2003 11:32 AM
JLH Class-A Amplifier Geoff Solid State 5 25th May 2001 11:55 PM
