Which Pass Aleph diy board for "no-cost-object" headphone amplifier? - Page 4 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 26th June 2010, 08:35 PM   #31
Originally Posted by bobodioulasso View Post
If you feel unconfortable with the volume at maximum, it is perhaps a matter of sensitivity of the amp, or wrong potentiometer value. In no way it can be a lack of power with earphones. Either you will be the first one in my knowledge.
That's interesting finally!
Consider that it works with 40 volts actually in front of 70 volts for the 400 watts in 8 ohms (I don't need them obviously!).
It is possibile that the problem could be the pot: I'm using a temporary pot before finish the project in his case with an Alps 100K: I'll try to change it.
But it is more interesting the possible sensitivity problem: if it is too low for the headphone purpose (remember that this amplifier was projected for loudspeakers), what could I do?
Thank you sincerely
Old 26th June 2010, 09:15 PM   #32
bobodioulasso's Avatar
Which source do you use? How many millivolts it produces, at which impedance?
Dou you know the input impedance of your amp, its sensitivity?
All these need to match either you cannot feed properly your amp with the signal.
Have you hooked speakers to this amp, you should feel the same problem. If there is a mismatch this will not affect the headphones specially.
Old 26th June 2010, 09:26 PM   #33
Thank you, I see. Tomorrow I'll measure and I'll say the values.
By the way, I believe to remember (I checked it) that the amplifier input impedance is 500k ohms about.
The source I usually use are standard cd players, sometimes also a cheap portable player (I study music and I need to move from a room to another very often: i can't carry everything everytime).
I Thank you very much. See you soon.
Old 26th June 2010, 09:49 PM   #34
The cd player I used for testing and for the first listenings to the amp is a 800.000 ohms output impedance (measured with really professional analog multimeter) and the amplifier near 500.000 ohms input.
Old 26th June 2010, 10:00 PM   #35
You can't measure an impedance with an ohm meter.
Feeding a power amp from a CD player should work fine.
Your pot value is may be quite high, try 50k or 22k
But it looks like your amp is particularly unsensitive.
Try with speakers.
Old 26th June 2010, 10:07 PM   #36
I know that it need an oscilloscope, but I haven't it... sorry...
Thank you for your time and availability.
Old 27th June 2010, 04:18 AM   #37
chinsettawong's Avatar
Hi Hammerklavier,
Do you really hook up your headphones to the amplifier to speaker output? Could you draw a simple circuit to show us how you hook up your headphones to your amp? I am very curious.
Wachara C.
Old 27th June 2010, 10:18 AM   #38
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by Hammerklavier View Post
Risus abundat in ore stultorum
http://edvinas.sideris.googlepages.com/AV400.pdf
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 28th June 2010, 07:05 AM   #39
Banned
Build EUVL's Dao Follower amp and incorporate a Salas shunt regulator.
Hard to beat.
Old 5th July 2010, 10:24 PM   #40
2quad is offline 2quad  Norway
2quad's Avatar
Default Smells fish?
Now this was a weird thread. Maybe it should have just died here. On the other hand, I just couldn't resist
You see, I own a pair of AKG 702's (among several other equally good 'phones). And the 702's are happy with just about everything I throw at it. I've tried Grace, Musical Fidelity, Benchmark...... Too little level is never a problem! Connect it directly to a non-valve CD-player output, and it's LOUD! Way too LOUD!
So, since this is a site for people with some technical knowledge, here's the spec's for the 702:
Sensitivity: 105 dB/V
Rated impedance: 62 ohms
Max. input power: 200 mW
Now, if we combine these spec's, we'll find:
1. Max. input VOLTAGE = 11 volts
2. SPL at 11 volts = 126 dB
So - do you smell fish now? An amplifier putting out levels far above what the 'phones can handle -- and it's still not loud enough?
There have been some hints to the source of the "not loud enough" problem. Did the thread starter ever answer to them?
New Amp "ULTRASYMMETRY" from Nelson Pass - still a Concept Amplifier? tiefbassuebertr Pass Labs 23 30th October 2012 09:02 AM
Who has the "best" PCM1704 DIY board/design/kit?? bear Digital Source 26 21st September 2012 01:43 AM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 07:12 PM
My A.N.T. "Amber" headphone amplifier x-pro Headphone Systems 8 1st October 2007 09:47 AM
Copyright ©1999-2017 diyAudio
