Headphone Systems Everything to do with Headphones
Which Pass Aleph diy board for "no-cost-object" headphone amplifier?
Old 26th June 2010, 06:29 AM   #21
Gordy is offline Gordy  United Kingdom
With your outlook of only one designer you have limited your choices.
All of the standard Pass designs have too much gain (amplification) for your AKG K702 headphones.
Gricko provided a good recommendation: http://www.diyaudio.com/forums/headp...phone-amp.html
My suggestions would be:
The Cavalli-Kan Kumisa III Stereo Headphone Amplifier
The SOHA II Headphone Amplifier
Old 26th June 2010, 09:53 AM   #22
Hammerklavier is offline Hammerklavier  Italy
thank you for your advice.
Old 26th June 2010, 10:16 AM   #23
Magura is offline Magura  Denmark
Magura's Avatar
If it has to be "out there", then a FirstWatt F4 suits your requests......note that I wrote "requests" rather than "needs".
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 26th June 2010, 10:17 AM   #24
EUVL is offline EUVL  Europe
I don't want to sound self-advertising, but if you intend to use the AK702, you should IMHO give this a serious consideration:
http://www.diyaudio.com/forums/pass-...ml#post1603771
With 6x ohm impedance, you need lot of current and not much voltage; also essentially no need for voltage gain. The cascoded LU1014 in triode mode is really ideal for the task. The DAO gives a perfect square wave output at 67 ohm.
Patrick
Old 26th June 2010, 06:22 PM   #25
Yes, that's the "problem". My amplifier could share (if properly alimented with 70 volts) 200 watts in AB1 class with normal loudspeakers. I obviously know that...
But with headphones it's a totally different matter: it's something that could be compared to a couple of very low efficiency loudspeakers with a very low impedance which need to set your amplifier volume on the maximum level ever: I don't like it and feeling that I'm near the amplifier limits ever when I use a high impedence headphones.
Because I'm not an engineer, but a person that really need to listen to music at high quality levels (and realistic volume), I thought that someone could have the same "problem" of mine and more experience about.
Thank you.
Old 26th June 2010, 06:28 PM   #26
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Is it me, or does your posts sound as that you're using the headphone socket of an integrated amp for a K702 ?
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 26th June 2010, 06:33 PM   #27
Magura's Avatar
Usually the answer to that question would be "yes it's you", but in this rare case, no it's not you
He sure is using the headphone socket, but since when has reason had anything to do with it?
Magura
Old 26th June 2010, 06:55 PM   #28
Risus abundat in ore stultorum...
By the way, I post my main circuit board If someone polite (perhaps in Italy we have a totally different conception of interpersonal behavior) would like to share and to argue about objective reproductions problems: if You don't feel some problems, it is a problem of yours, not of who have them.
Arturo Benedetti Michelangeli was just fool or a "science oriented" artist able to hear things as they were really?
Thank you very much indeed to all answer with praiseworthy intentions.
See you soon.
Old 26th June 2010, 06:59 PM   #29
P.s.
It is for one channel only. It works with N.4 IRFP240 + N.4 IRFP9240
300 mA bias
Old 26th June 2010, 07:15 PM   #30
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
If you feel unconfortable with the volume at maximum, it is perhaps a matter of sensitivity of the amp, or wrong potentiometer value. In no way it can be a lack of power with earphones. Either you will be the first one in my knowledge.
Which Pass Aleph diy board for "no-cost-object" headphone amplifier?Hide this!Advertise here!
New Amp "ULTRASYMMETRY" from Nelson Pass - still a Concept Amplifier? tiefbassuebertr Pass Labs 23 30th October 2012 08:02 AM
Who has the "best" PCM1704 DIY board/design/kit?? bear Digital Source 26 21st September 2012 12:43 AM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 06:12 PM
My A.N.T. "Amber" headphone amplifier x-pro Headphone Systems 8 1st October 2007 08:47 AM
