diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Headphone Systems (http://www.diyaudio.com/forums/headphone-systems/)
-   -   Need Help with Earbud repair (http://www.diyaudio.com/forums/headphone-systems/166082-help-earbud-repair.html)
Normanio 30th April 2010 05:34 PM
Hello everyone,
I am new to this forum as well as audiophile itself so please bear with me. I have a pair of V-Moda earbuds w/mic that fell victim to the common "earbud sound loss" in one ear. I've decided to fix them myself for they will not honor a warranty due to me purchasing from an unauthorized seller. I narrowed my failure at the junction where the 2 earbud wires (1 from each ear) meet to make 1 thicker wire down to the jack. I also decided to replace the jack with one from Switchcraft due to many folks reporting of failures there. My question to the community is: Can I just solder (the two wires from ear buds and one from headphone jack) together at a three-way union and just heat shrink the overall joint? Also there are two tabs that are on the Switchcraft, where do I put the wires to solder and which wire/and tab is ground? Do I simply solder the ground wire to the fatter tab and twist the other two wires together and solder them together at one point on the other tab? I am trying to gather as much info as I can before I go screwing things up and end up spending more money. Thanks everyone.
budgie14 17th June 2010 12:00 AM
depends if you want stereo or happy with mono[they were stereo,were they?]
Ron E 29th June 2010 02:19 AM
Stereo plugs are TRS (tip ring sleeve) the tip and ring are left and right (can't remember which is which - do a search), and the sleeve is ground. The head phone wires wiill have a center conductor and a conductor around that which serves as a ground. both outer conductors go to the sleeve and the inner conductors go to the tip or ring.
Resources saved on this page: MySQL 18.75%
