| Headphone Systems Everything to do with Headphones |
#11 | |
I'm building in Caddock or Rikens on my TRS jacks for my adapter box, to protect my amp, but also to knock down the power a bit to protect the cans since it will be putting out about 7W at 60R or over 15W at 6R. |
#12 | |||
If the amp can drive say, 32 ohm 'phones, then it shouldn't require any more than 32 ohm resistors. Quote:
Use something along the lines of 30 ohms for the series resistor, then select the shunt resistor to give you the highest listening level you'll need plus a little extra. It will be only a fraction of the 30 ohm resistor. Good luck! se |
#13 | |
I think the higher values were recommended to protect the amps on the small surge with the short. There is certainly enough power there to drive right through a 100-200R network. My 35W/ch vintage Yamaha CR-620 has a 121R resistor network for each headphone jack. Thanks for the value suggestions on the resistor network. There is a web page that has the formula for calculating the values based on the wattage output of the amp and the impedance of the headphones, but I don't have it handy. |
#14 |
Just stumbled across this thread. (oops!)
I've run balanced for years with a single connector. 4 pin DIN! The locking, screw type with metal body. Works great for me. And I have a short DIN to 1/4" cable that I use when I need to go back to unbalanced. Not tiny, but smaller and lighter than XLR, for sure. Got the metal DIN at Mouser or Digikey, I think.
Take the Speaker Voltage Test! |
#15 |
Has anyone attempted using 3-wire shielded microphone cable? My ratoinale is that cross talk from the twisted pair to the third wire should be minimal because the equal and opposite currents should create canceling fields. Any 'crosstalk' from currents in the single wire would cancel in the can connected to the twisted pair.
There are 3 wire microphone cables, for example from Gotham, that are ultra flexible though not necessarily small diameter. |
#16 |
On top of the actual cable change, I'd be really tempted to add a small RC zobel right on the transducer to "terminate" the cable.
#18 |
As the following thread shows, I am not the first to consider this.
Tying in shield for headphone cables (esp. balanced situations)? The history of bal<->unbal is littered with hums, screeches, and worse between components, but allow me to point out that cans are not a component in the traditional sense. They are more like an MC cartridge, i.e. inherently balanced, while being capable of rejecting common noise. Please help me discard this idea before I go off and build one if I am "thinking inside the cable" and missing something important. |
#19 |
Any kind of zobel network would be for ensuring amplifier stability, as it keeps load impedance low up to the MHz range. This should only be of concern to amplifier designers (in an ideal world where they can be relied on to know what they're doing).
Indeed, headphones are much like a phono cartridge, inherently balanced and floating. One of the more important points in wiring them up unbalanced is keeping the returns separate for as long as possible, as return resistance common to both channels degrades channel separation. Stock cables for the usual suspects (HD5x8, HD6x0, various AKGs etc.) implement that already. Even a common ground connector does not necessarily spell disaster though, as long as its resistance is less than about 1% of minimum driver impedance. (Example: HD590, ~1 ohms vs. 100 ohms.) 40 dB of channel separation should be plenty on cans if even 12 dB of imbalance already is painful and vinyl gets along fine with <30 dB. Ideally, the cable for a balanced headphone connection should have either 2 conductors and a shield per channel, or 4 conductors plus shield for both. Shield would be connected at the amp only. Anyway, people tend to put a lot of emphasis on electrical characteristics. IMO, they're not even all that important (assuming capacitance doesn't skyrocket or resistance exceeds ~10% of minimum impedance). You do want the cable to be light and mostly devoid of microphonics though, and it would be nice if it didn't break after a week of use. Sennheiser had massive cable reliability problems with the thin copper cables they originally supplied with HD414s way back when, so they eventually switched to somewhat microphonic but tough steel-conductor cables (still to be had with HD25-1s these days). It would take them about 15 years to come up with the kevlar fiber reinforced copper cables they usually supply nowadays (low microphonics and decent durability). |
#20 |
Thanks for the rules of thumb for cable resistance. My first attempt was with Mogami 3106 stereo microphone cable. Twin pairs of twisted conductors, separately shielded so it fully meets your ideal. It leaves something to be desired in terms of useability. I recently held a length of Gotham GAC-3 and thought how wonderful it would be to have that flex in a headphone cable. That started my 'inside the cable' thoughts.
Now I am questioning what parts of the ideal might be relaxed at little (or better, no) loss in quality. Is shielding really needed? Might it instead be used as the fourth conductor? It was at that point that I posted my thoughts above and then found RaneNotes on shielding, grounding, and audio interconnect. My thoughts fall under "Floating, Pseudo, and Quasi-Balancing" but I am undeterred :-( Gotham has graciously provided three and four conductor cabling at what seem to me quite low prices. Surprisingly they sell cut lengths to one and all. I will add connectors and test for crosstalk differences between GAC-3 and GAC-4 (four conductors in a single shield). I will also test against Mogami dual, separately shielded, twisted pair. |
| Why are headphone cables shielded? | jaencer | Headphone Systems | 4 | 7th March 2010 05:18 PM |
| Balanced vs/ Umbalanced (cables, inputs, ans so on ...) | teodorom | Everything Else | 11 | 18th November 2008 11:20 AM |
| Good places in the UK to buy balanced audio cables? | VvvvvV | Multi-Way | 1 | 10th August 2005 09:00 PM |
| Looking for affordable, good sounding, balanced interconnect cables | Peter Daniel | Solid State | 11 | 19th June 2004 06:15 PM |
| Page generated in 0.54478 seconds (100.00% PHP - 0% MySQL) with 9 queries |
