Headphone Systems Everything to do with Headphones
The Tringlinator: a MOS-based Tringlotron amplifier
Old 15th April 2010, 12:17 PM   #1
Elvee is offline Elvee  Belgium
Elvee's Avatar
Default The Tringlinator: a MOS-based Tringlotron amplifier
Using MOS devices in a Tringlotron topology brings a number of benefits.
The Tringlinator shows a 250mW example.
It is a two-stage design, using no negative feedback.
Yet, thanks to the oustanding error-correction properties of the Tringlo (TRIplet of N-device Grouped in Line) topology, the THD can be as low as 0.001%. (Note that this is a real error-correction scheme, not some NFB in disguise).
The damping factor is in excess of 10,000.
M1 and M2 have to closely match and must be tightly thermally coupled.
The input section provides the voltage amplification and is a variation on the Xquad theme.
Old 21st April 2010, 12:12 PM   #2
Gordy is offline Gordy  United Kingdom
I've not had time to study the topology yet, however I see that Tringlotron gets a mention on TubeCad.com this month: Tringlotron
Good luck with it.
Old 21st April 2010, 12:53 PM   #3
forr is offline forr  France
forr's Avatar
Just before reading this thread, I found this one yesterday (it's in french) :
Applications du Tringlotron à des amplificateurs de classe Audiophile - Forum Projets électroniques
Old 21st April 2010, 05:42 PM   #4
jcx is offline jcx  United States
after a quick look I would call it "error compensation/cancelation" - for me "error correction" involves a 'measurement" of the error and then involves feedback or Black's output error feedforward
this circuit relies on device matching for the similar Vgs errors to cancel out
Old 22nd April 2010, 02:50 PM   #5
Elvee's Avatar
Compensation, correction, cancellation.... it is debatable.
"Error cancellation" is probably the most accurate.
But one thing is unquestionable: there is no NFB involved.
Old 22nd April 2010, 03:58 PM   #6
Elvee this looks very interesting. I have a question regarding the bias of M2: the rsisitors R5 and R6 seem to only provide bias for M2, so whay are they relatively low values (k Ohm not M Ohm)? Also, I do not understand why R13 and C2 are across R6... what do they do?
(Thank you)
Old 22nd April 2010, 07:08 PM   #7
except for the local feedback around every transistor in the cirucit
I like making the "no feedback" crowd have to admit they're splitting hairs by distinguishing between "local" and "global" feedback
then mayabe some will ask how come one type of negative feedback is always "good" and the other "bad" - or if its true at all
Old 22nd April 2010, 09:28 PM   #8
00940 is offline 00940  Belgium
00940's Avatar
Fascinating link.
I quote (and translate) the original post conclusion:
The TRiNGLotron (TRIplet of NPNs Grouped in Line) is a topology linked to the Biglotron.
Let us remind you that the founding principle of the Biglotron, a creation of Pr. Jérémie Ménerlache, is to serve absolutely no purpose. This foundation allows the Biglotron to be used for virtually anything, conferring it an amazing potential and justifying its status as secret weapon.
The Tringlotron, invented by Ludwig Von Bürnmoll is based on the same principle as its famous ancestor, but is less pretentious. It is not very useful and is thus susceptible to be used for many things.
This is already not too bad by itself, as we will see later on.
The whole thing was posted on the first of April...
All that is excessive is insignificant. Talleyrand
Old 22nd April 2010, 09:38 PM   #9
Jen-B is offline Jen-B  United Kingdom
Originally Posted by 00940 View Post
Fascinating link.
Then someone tell this guy at ElectronicDesign.com, who posted on April 7th !!! :
http://electronicdesign.com/article/ideas-for-design/novel_buffer_topology_cancels_nonlinearities.aspx
Old 23rd April 2010, 09:23 AM   #10
Elvee's Avatar
(Thank you)
The bias provided by R5 and R6 is fixed; there is no signal superimposed there, and the node is decoupled to the ground by C2.
R13 is a gate stopper and has an unusually low value because even with ten's of ohms, the Cgd of M2 is sufficient to add some ppm's distortion.
Depends where you draw the line: if you consider a common collector stage has 100% feedback, then there is indeed feedback everywhere.
But from that perspective, how would you create a no-feedback unity-gain follower?
BTW, I personally have nothing against NFB, and this is more an exercise in style than anything else.
The Tringlinator: a MOS-based Tringlotron amplifierHide this!Advertise here!
VSP LABS Trans Mos Amplifier TomWaits Solid State 32 8th April 2017 11:47 AM
I wang to do it:uhc mos amplifier uhcmos Solid State 2 21st February 2007 11:50 PM
n-mos half-bridge class D amp, how to drive high side n-mos? zilog Class D 1 30th October 2005 09:46 PM
mos-fet amplifier question ... B.I.G Solid State 29 1st March 2005 08:13 PM
Mos Amplifier Design f.bcn Solid State 10 12th November 2002 11:13 PM
