Headphone Systems Everything to do with Headphones
CMOY shootout!
CMOY shootout!
Old 18th October 2011, 11:25 AM   #61
taliesyn is offline taliesyn  Wales
My next aim is to build a 'Sijosae' discrete rail splitter for the Banzai amp, instead of the resistor divider splitter which should be fun
Old 18th October 2011, 06:15 PM   #62
mikesnowdon is offline mikesnowdon  United Kingdom
mikesnowdon's Avatar
Cool!
www.drugfreeworld.org
Old 16th January 2012, 09:05 PM   #63
Haz is offline Haz  United Kingdom
I've built a cmoy amplifier and I like it very much. But my question is could I use a NE5532 to turn it into a preamp? I've looked over the cmoy schematic and schematic for a NE5532 preamp and it looks almost the same!! There's a few 0.1uf capacitors on the NE5532 schematic that bypass the +12v and -12v to ground, 100pf to signal input to ground that's it.
I know I probably have to change the resistors to change the gain. It will be used to boast the out signal to a friends computer speakers. nothing really high end!!
Old 28th January 2012, 05:22 PM   #64
sgrossklass is offline sgrossklass  Germany
Sure, you can always use one of these to provide some voltage gain. As you noticed, it's the same kind of circuit.
CMOY shootout!Hide this!Advertise here!
DHT drivers - shootout andyjevans Tubes / Valves 28 14th April 2010 07:47 PM
Tripath chips shootout oon_the_kid Class D 10 31st May 2009 02:53 AM
Shootout: ZBM4 vs. ZMV5 (?) diesel_88 Multi-Way 1 29th March 2009 02:00 AM
6J5 Shootout - which one's best? Rodango Tubes / Valves 7 6th May 2008 09:03 PM
300B shootout aldovan Tubes / Valves 25 21st January 2008 04:56 PM
