my tube headphone amp-> need feedback
OK... so I am to try it... :dead: Well, with the limited budget I have, that can get hairy. :)
The only two tubes I can find any info about are the 6DN7 and 6EM7. The 6EM7 has a 750-ohm Ra, so it's output impedence would be quite a bit lower than my headphones, though it has a much higher gain. (60 on first half)
Am I correct in assuming the high gain goes first, followed by the lower gain as output? And, the output half gets higher voltage... what, 200V? 250? First half gets about what as well? I have some difficulty decifering the tube terminology. What mA rating tranny would I need? If I read the data sheets correctly, Ip was VERY high, maybe reaching 80 on one of these tubes (forget which). On a dual triode? Gee... That would require a lot more current that $30 or so can buy.
What is the main reason that you want the output impedence lower than the impedence it is driving on OTL's? Does it increase THD?
Ex-Moderator
Joined 2003
Electromagnetic loudspeakers rely on being driven from a low source resistance to achieve correct bass response. Headphones were traditionally driven via large resistors from the output of power amplifiers, so they didn't have this benefit. However, modern equipment with headphone sockets drives them from dedicated amplifiers, which inevitably have low output resistance. The question is, have the headphone manufacturers taken any notice?
Nahh, it's no problem!
You might need that gain, well then again maybe not.. I don't know. If nothing else you can burn it off with global NFB or voltage dividers.
Yes.
The CF I designed for +250V. You could use +200V for the first stage.. it doesn't really matter.
Nope. Look at my graph again - it's for its own operating point, has nothing to do with published values for typical operation. (After all this isn't typical operation for a vertical amplifier!)
It shows Iq (quescent (fancy word for the DC or standing value) current) = 20mA. So for stereo you need 40mA, plus whatever the driver stage takes. 50mA total should suffice.
No, it doesn't have much to do with THD; it's more of a frequency response issue. Speakers are never ideal resistors, instead complex combos of electrical and mechanical reactance (in a nutshell, reactance is resistance that varies with frequency, such as a capacitor or inductor's response). An 8-ohm speaker might be 8 ohms at 400Hz, but as low as 4 or 6 ohms at 200Hz, and 12 or even 16 at maybe 100 or 50Hz...
The reason for having a high damping factor (DF = Rl / Zo) is to level these bumps, giving a more even response.
On the flipside, you might well prefer a constant-current output (one with a high Zo) instead.
Tim
