Headphone Systems Everything to do with Headphones
JLH Headphone Amp
JLH Headphone Amp
Old 8th December 2012, 09:59 PM   #361
bkercso is offline bkercso  Hungary
Good built, nice! But I would use shielded coils in output integrators.
How does it sound (eg. vs JLH or vs 30 years old Danish "HP-Amp")?
Tripath TPA series is often used for amp and HP amp too. Here is a Muse one: link. There is a combined version (equivalent with this buit with 6.3 Jack connector in the front) but I don't find that. This is class-T, I don't know exactly what is the difference.
Old 9th December 2012, 07:13 AM   #362
oz7aff is offline oz7aff  Denmark
oz7aff's Avatar
I se no reasons for shielding the coils, no hum fields inside the cabinet.
This amplifier uses a TPA3122 IC, and the sound is a little thin I think. But the amplifier is well suited for headphone amp because it has common ground at the output, some of these amplifieres does not have this and therfore need rewired headphones. That goes for the Muse also, it is not fit for headphones.
But this amplifier is cheap and very easy to work with and it also runs on a single 12V supply and deliver up to 15W class D.
2 x 15 Watt 8 Ohm Class D Audio Amplifier DIY Kit TPA3122 15W Stereo Amp | eBay
Regards Max
Old 29th April 2013, 08:24 PM   #363
sangeet2 is offline sangeet2  Germany
Hello Miles,
I made the modifications you described and everything worked well. However
there was hum cause the Transformer was to close. I decided to put the transformer in an extra case. When I connected everything and powered up and measured voltages everything was fine. Exept that I could not measure an AC Voltage that shoud double on the both secondaries...
So I put my headphone up and there was the most terribel hum I ever noticed!
I was wondering if I have to connect the earth coming from the mains to the
both secondaries which are combined for 0V.
Old 30th April 2013, 08:46 AM   #364
Ok, I found out that after putting the transformer back, I mixed up secondaries connections…
how embarrassing
After the connections are back proper, there is still too much hum. Is it possibel that something got destroyed?
Old 30th April 2013, 09:29 AM   #365
DC offest is -31mV and 50mv
Old 30th April 2013, 10:55 AM   #366
Ok, all good again, I had an earth loop…still dont know why, but for the moment I am happy again
Old 1st May 2013, 02:03 PM   #367
You should measure DC offset when amp is warmed up. The offset difference between cold and warm state is about 100mV. Anyway, up to 50-100mV DC is acceptable for headphones.
Old 1st May 2013, 05:14 PM   #368
Telstar is offline Telstar  Italy
ahem I'm not so sure about that
I try to stay under 5mV for 'phones and 100mV for speakers.
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Old 1st May 2013, 05:28 PM   #369
EUVL is offline EUVL  Europe
Take a low impedance headphone of 32 ohm (e.g. Beyerdynamic DT990-32).
Power handling of the headphone is specified at 100mW.
http://europe.beyerdynamic.com/shop/...90_DB_E_A3.pdf
100mV DC => 0.3mW. So that makes 0.3% of specified power ?
Patrick
xen-audio.com
Old 1st May 2013, 06:52 PM   #370
No problem with 100mV also @phones, trust me! Anyway, it is clipping when switch the amp ON/OFF. For no clipping <10-20mV is desired (depends on phone's impedance and SPL).
JLH Headphone AmpHide this!Advertise here!
JLH headphone amplifier steveh49 Headphone Systems 8 14th May 2014 03:31 PM
JLH Headphone amp aethelbert Headphone Systems 4 13th July 2009 11:14 PM
JLH headphone amp with FET's and servo nelsonvandal Headphone Systems 17 30th August 2008 09:26 PM
PCB for JLH amp FaTTy Solid State 0 27th March 2007 04:40 PM
