| Headphone Systems Everything to do with Headphones |
#331 |
Well actually, you only want as much DC across a 'lytic as is necessary to keep it in good working order. At higher voltages, distortion actually increases, as Cyril Bateman found. Introducing some DC offset should be easy in the JLH, as it requires some offset trimming anyway.
Basically the largest disadvantage of using coupling caps is their size. Ideally you're looking at something like 1000µF per channel. |
#332 |
I have the blue PCB and has nothing to do with the green. The blue remains perfectly the offset about 10 mvolt or so.
#333 |
Blue PCB:
On a hour, the offset is constant, around 15 mVolt more less. The sound is good. I think that the board desing (the path of the track and its travel is totally different) and the quality component is the differece. I think that the green board "JHL" it´s a c***p...
#334 |
I built 2 blue ones and during warm up the offset changed ~100mV at both amp.
#335 |
On Max´s unit, when start, the offset is ~180 mVolt and down to 10~30 Volt after 1 hour.
#336 |
I used 4x1N4148 per channel as recommended in this topic, and trimpot.
#337 |
Is that instead of the 2V7 Zenerdiode ?
Regards Max |
#338 |
Yes.
Oh, sorry! Only 3x1N4148 per channel. |
#339 |
Ok, I think one could also try to use a LED instead.
Regards Max |
#340 |
LED has more noise than 4148. Red LEDs are less noisy than others.
| JLH headphone amplifier | steveh49 | Headphone Systems | 7 | 5th September 2011 05:05 AM |
| JLH Headphone amp | aethelbert | Headphone Systems | 4 | 13th July 2009 11:14 PM |
| JLH headphone amp with FET's and servo | nelsonvandal | Headphone Systems | 17 | 30th August 2008 09:26 PM |
| PCB for JLH amp | FaTTy | Solid State | 0 | 27th March 2007 04:40 PM |
