Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 16th November 2012, 06:40 PM   #321
mkusan is online now mkusan  Croatia
Hi blackdod,
thank you for pictures, I don't believe uploaded schematic applies to your version of the board. If you are worried about those lifted tracks check for continuity with DMM to be sure , however I don't expect problems there. Cleaning the flux from the board with some alcohol wouldn't hurt either. If you feel confident and you are good at desoldering change input ceramic cap to 1uF film type, not sure if WIMA would fit here because lack of space, if not try Panasonic ECQ-V series. If all goes well replace two Zener diodes on the board each with 4x1N4148 connected in series, observe the polarity it is opposite to the zeners.
Marko
Old 16th November 2012, 07:42 PM   #322
Thanks Marko
I followed all scheme and is not compatible with my amp on some points.
I'll think I do. I did not want to spend much time on this amp because it is a "smaller" project and I have other amps outstanding.
Thanks for your patience
Old 16th November 2012, 07:51 PM   #323
oz7aff is offline oz7aff  Denmark
oz7aff's Avatar
Hello blackdod
The biggest difference between your green PCb and my blue PCB, is that my heath sink is at least twice the size of yours.
But if you mail me your postal adress, then I will send you a blue PCB at no cost.
Regards Max
Old 16th November 2012, 08:08 PM   #324
Originally Posted by oz7aff View Post
Hello blackdod
Thanks Max but I canīt accept that. Let me pay you the plate and sending.
I will change the input ceramic capacitors and some bridges because are rusty only by test.
Old 16th November 2012, 08:24 PM   #325
Hello blackdod
This is why I love this forum so much, indeed a true DIY spirit.
Regards to you Max
Marko
Old 16th November 2012, 08:32 PM   #326
Regards to you Max
Marko
Of course
Old 18th November 2012, 07:13 AM   #327
oz7aff's Avatar
Hello blackdod
I forgot to say that you can send mail to me via my homepage www.sandcastle.dk
Regards Max
Old 19th November 2012, 11:15 AM   #328
If output coupling caps are added to protect the headphones from the output dc offset, is there any reason to aim for 0V dc offset upstream of the cap?
I have a pair of ASC GLY513 600uf fim caps that I'm mounting in a separate enclosure with 6.35mm stereo in and out to allow me to use these caps with any headphone amp I'm using. With these film caps it won't damage anything if the offset is positive or negative, but I wondered if setting the offset to +1vdc (making the signal vary from 0-2vdc in normal use) would be best.
In the meantime I have a pair of black gate 1000uf 16v standard polar caps at the output, so setting the offset to +1vdc keeps the polarity of the signal correct for the polar cap.
Any thoughts?
Old 19th November 2012, 11:48 AM   #329
oz7aff's Avatar
Just remember that the original JLH class A amp from the sixties had single supply, and there for 1/2 Vcc as offset and only a standard electrolyt in the output, and this arrangement works very well. I think that the answer is, lisent to it, does it sound good, then it is good.
Regards Max
Old 19th November 2012, 02:42 PM   #330
ashok's Avatar
If you use a capacitor at the output , it might be better to use a single supply circuit. That would bias the output cap at 1/2 Vcc. Electrolytics with no dc voltage across them aren't really operating in a comfort zone. Even a non polar electrolytic might not be the best solution here.
Like oz7aff said. Try out the way you want to do it and see how it sounds. It finally depends on if the sound is acceptable to you.
Have fun !
AM
JLH headphone amplifier steveh49 Headphone Systems 7 5th September 2011 05:05 AM
JLH Headphone amp aethelbert Headphone Systems 4 13th July 2009 11:14 PM
JLH headphone amp with FET's and servo nelsonvandal Headphone Systems 17 30th August 2008 09:26 PM
PCB for JLH amp FaTTy Solid State 0 27th March 2007 04:40 PM
Copyright Đ1999-2013 diyAudio
