Headphone Systems Everything to do with Headphones
JLH Headphone Amp
JLH Headphone Amp
Old 14th November 2012, 08:08 PM   #311
blackdod is offline blackdod  Europe
Yes, I change the Vr1-2 for trimpot 20 turn-off (10K), the offset value down much and is easier to control,... but was still very unstable depending of the temperature
Old 14th November 2012, 09:17 PM   #312
oz7aff is offline oz7aff  Denmark
oz7aff's Avatar
In this Thread there have been talked about some errors on that PCB, have you corrected them ?
Regards Max
Old 14th November 2012, 10:37 PM   #313
bkercso is offline bkercso  Hungary
Originally Posted by oz7aff View Post
Ok, I see that the schematic is the same as used in the blue PCB. There is an error on it C23 and C24 shall have + to GND.
C23/24 see AC voltage so it don't matter. You should use non polarized audio cap (or two series cap) here.
Old 15th November 2012, 11:48 AM   #314
oz7aff's Avatar
No, there is no AC voltage on C23/24. Standart elektrolytics are all right, but they shall be connected with + to GND.
By the way, at startup I measure about 100 mV Offset, and after 5 min. the Offset is down to 5 mV and stays in that area.
Regards Max
Old 15th November 2012, 06:37 PM   #315
I suppose that this pcb have some problem... I'm thinking buy the new version (blue PCB).
What do you think?
Old 15th November 2012, 07:09 PM   #316
mkusan is offline mkusan  Croatia
What do you think?
I believe, apart from the color of course, they are the same, so there is no point doing that.
There is a build guide with pictures made by Miles Campbell in this thread, did you have a look at it and measured various voltages on the PCB as advised.
It would be also helpful if you post pictures of your build (both sides of the PCB).
Hope you will sort it
Marko
Old 15th November 2012, 07:44 PM   #317
Tomorrow I will take some pictures of this PCB
By the pictures, I suppose that the components are the "best" quality on the blue PCB ¿?
Old 15th November 2012, 10:17 PM   #318
Hm, really, sorry! I misunderstood the schematic... But I used 2 series caps here and the sound is clear, detailed.
According to simulation there is really about -1V. I will not take apart it now for a measurement...
The offset is almost the same at my both JLH amps. I built these according to Miles Campbell's build guide, except I used multiturn cermets and trimmed the offset.
Old 16th November 2012, 07:47 AM   #319
No, I don't believe that better quality parts come with newer blue PCB kit,
e-bay sellers use what is available to them and cheapest at a given time.
Replacing input caps with something better like WIMA as oz7aff suggested is worth doing, C23/24 could probably benefit from better parts as well.
Marko
Old 16th November 2012, 05:14 PM   #320
Rear:
And I don´t like this (around C32 and C26)
JLH Headphone AmpHide this!Advertise here!
JLH headphone amplifier steveh49 Headphone Systems 8 14th May 2014 03:31 PM
JLH Headphone amp aethelbert Headphone Systems 4 13th July 2009 11:14 PM
JLH headphone amp with FET's and servo nelsonvandal Headphone Systems 17 30th August 2008 09:26 PM
PCB for JLH amp FaTTy Solid State 0 27th March 2007 04:40 PM
