Headphone Systems Everything to do with Headphones
JLH Headphone Amp
JLH Headphone Amp
Old 12th November 2012, 08:32 PM   #301
oz7aff is offline oz7aff  Denmark
oz7aff's Avatar
Have a look here:
If the meter shows 140 mV, then the current through the capacitors is 14 nano Ampere, that's 0.000000014 Ampere, it is simply the leakage current you are measuring.
Regards Max
Old 12th November 2012, 08:36 PM   #302
blackdod is offline blackdod  Europe
Thanks Max
I would like change the ceramics capacitors of the input and something else, nothing complicated.
What do you think?
Old 12th November 2012, 08:40 PM   #303
Originally Posted by oz7aff View Post
Have a look here:
Ok Thanks...
I didnīt know this
Old 12th November 2012, 09:14 PM   #304
oz7aff's Avatar
Normaly there will by no problem in changing the type of capacitors.
Is there a way I could see the schematic ?
Regards Max
Old 12th November 2012, 09:35 PM   #305
Yes, I have the schematic and I can see that the input capacitor is marked with the number of 1U on my board (value 1 uF on the schematic ŋ?), just after the volume pot.
Old 12th November 2012, 09:40 PM   #306
oz7aff's Avatar
But I have no schematic to look at, is there any place I can see it ?
Regards Max
Old 13th November 2012, 11:47 AM   #307
mkusan is offline mkusan  Croatia
I believe you can, here it is thanks to Miles Campbell.
Old 13th November 2012, 02:07 PM   #308
oz7aff's Avatar
Ok, I see that the schematic is the same as used in the blue PCB. There is an error on it C23 and C24 shall have + to GND. And why use a capacitor on the output ?
Replacing the input capacitors with some 1 uF plastic type like Wima should be OK.
Regards Max
Old 13th November 2012, 05:15 PM   #309
Hi guys
Ok, itīs the schematic. Thanks Mkusan.
Well, I used a cap on the output because I measured the voltage between the Output pad and signal ground and the volt was around 500 mVolt.
Old 13th November 2012, 08:42 PM   #310
oz7aff's Avatar
It should be possible to reduce the offset there by means of VR3/4
Regards Max
JLH Headphone AmpHide this!Advertise here!
JLH headphone amplifier steveh49 Headphone Systems 8 14th May 2014 03:31 PM
JLH Headphone amp aethelbert Headphone Systems 4 13th July 2009 11:14 PM
JLH headphone amp with FET's and servo nelsonvandal Headphone Systems 17 30th August 2008 09:26 PM
PCB for JLH amp FaTTy Solid State 0 27th March 2007 04:40 PM
