Headphone Systems Everything to do with Headphones
JLH Headphone Amp
JLH Headphone Amp
Old 9th November 2012, 05:25 PM   #291
blackdod is offline blackdod  Europe
Well, I don“t believe that the problem be the capacitors... I used a pair of Nichicon electrolytic capacitors on serķe and the result is the same.
The offset on this ampli is a "russian-mountain"
Old 10th November 2012, 01:31 PM   #292
oz7aff is offline oz7aff  Denmark
oz7aff's Avatar
I don't know the meaning of "russian-mountain".
But I know that if you'r setup is like this:
There shall be no DC offset to measure with the VDC meter.
Regards Max
Old 10th November 2012, 07:04 PM   #293
Thanks for your answer.
Yes, is my setup, but I never take the DC values with the headphones connecting.
PD: "russian-mountain"; when something mimics the movement of a roller coaster.
Old 10th November 2012, 07:47 PM   #294
oz7aff's Avatar
Then you can't use the measurement, try to connect a 1 kOhm resistor as a dummyload.
Regards Max
Old 10th November 2012, 08:08 PM   #295
Originally Posted by oz7aff View Post
... try to connect a 1 kOhm resistor as a dummyload.
Thanks Max, I“ll try.
Old 12th November 2012, 07:43 AM   #296
bismuth is offline bismuth  France
Thanks Max
Well, the offset is around 140 mVolt when the my amp is warm (with the Non Polar Cap) and I don“t like this. IMHO, 140 mVolt is very dangerous for a headphone. I supposed that with this Cap, the offset would have be around 0 mVolt.
There is maybe something wrong elsewhere with your board, mine is barely around +-25mV Offset at startup, and it goes down to around +-3mv after around 10 minutes when warm, and I have NO capacitor on output, only 2,2uF on input.
Old 12th November 2012, 07:28 PM   #297
Thanks guys
If I conecct a resistor on the output, the offset is 0 mvolt, but I think that my board have any problem because when I start it up (with out dummy load) the offset goes down to 200 mVolt to around 0 mVolt and when it warns up goes to 140 mvolt
I will check the rest of the board.
Old 12th November 2012, 07:56 PM   #298
oz7aff's Avatar
As I said before, the measurements without the resistor is of no value, measuring on a capacitor without connection on both side is a waist of time.
Regards Max
Old 12th November 2012, 08:21 PM   #299
Thanks Max. Do you think the amp It“s ok?
Old 12th November 2012, 08:24 PM   #300
oz7aff's Avatar
If there is no Offset voltage with the 1 kOhm Dummy load, then I am shure that the amplifier is working OK.
Regards Max
JLH Headphone AmpHide this!Advertise here!
JLH headphone amplifier steveh49 Headphone Systems 8 14th May 2014 03:31 PM
JLH Headphone amp aethelbert Headphone Systems 4 13th July 2009 11:14 PM
JLH headphone amp with FET's and servo nelsonvandal Headphone Systems 17 30th August 2008 09:26 PM
PCB for JLH amp FaTTy Solid State 0 27th March 2007 04:40 PM
