Headphone Systems Everything to do with Headphones
JLH Headphone Amp
JLH Headphone Amp
Old 6th November 2012, 06:43 PM   #281
blackdod is offline blackdod  Europe
I´ve got Ebay´s old version (green board) and the sound is not bad, no noise or HUM, but the offset is a really nightmareĦĦĦ
I can´t keep this parameter controlled around 50mV.
Old 6th November 2012, 07:44 PM   #282
oz7aff is offline oz7aff  Denmark
oz7aff's Avatar
How about building at servo for it ?
Regards Max
Old 6th November 2012, 08:40 PM   #283
bkercso is offline bkercso  Hungary
Try to use 4x1N4148 instead of 2.7V Zener.
If you trim the DC offset to 0V after warm up you get about 100mV when amp is cold (and vice versa). Try to trim around 50mV after warm up and when cold get -50mV (or vice versa? ).
Old 7th November 2012, 06:13 PM   #284
Thanks guys
I've been working for a very little time in the amp because I´ve got another headphones amp (B22...)
I´ve made some changes on the original JHL,like this:
A) Trimpot 10k (20 turn off)
B) Nichicon Non polar (1000uF/25volt) on the out put.
I haven´t got any DC Servo.
As much the temperature grows, the offset change too.
Old 7th November 2012, 06:25 PM   #285
Well, the board have got 6x1N4148 but if you take a look, two others missing
Old 7th November 2012, 08:04 PM   #286
oz7aff's Avatar
Because you got these I think that you don't have to care about the offset as long it stayes below something like 100 mV
Regards Max
Old 8th November 2012, 06:27 PM   #287
Thanks Max
Well, the offset is around 140 mVolt when the my amp is warm (with the Non Polar Cap) and I don´t like this. IMHO, 140 mVolt is very dangerous for a headphone. I supposed that with this Cap, the offset would have be around 0 mVolt.
I´m thinking change the input cap for a Wima 1uF or add other Non Polar Cap on the output (on series) ż?
Old 8th November 2012, 07:11 PM   #288
oz7aff's Avatar
Do you have schematic of the Amp ?
My headphones have a resistance of 160 Ohm's, so with 140 mV offset the current will be under 1 mA and that will not harm the phones in any way.
Ps: is the headphones connected to the amp through a capacitor ?
Regards Max
Old 8th November 2012, 07:33 PM   #289
Yes; amp out put--cap--headphones
Yes I have got the schematic and a fantastic article by Papa Nelson
But reality, I don´t want to spend much time on this amplifier.
I have some headphones, from 32 Ohm to 600 Ohm.
Old 8th November 2012, 10:23 PM   #290
oz7aff's Avatar
Then there should be no offset at all, the cap must be bad, must have a very large leakage.
Ps: the hole meaning of capacitors is that you can't put DC trough them, only AC.
Regards Max
JLH Headphone AmpHide this!Advertise here!
JLH headphone amplifier steveh49 Headphone Systems 8 14th May 2014 03:31 PM
JLH Headphone amp aethelbert Headphone Systems 4 13th July 2009 11:14 PM
JLH headphone amp with FET's and servo nelsonvandal Headphone Systems 17 30th August 2008 09:26 PM
PCB for JLH amp FaTTy Solid State 0 27th March 2007 04:40 PM
