JLH Headphone Amp - Page 26 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 21st August 2012, 02:04 PM   #251
robertor's Avatar
Send a message via Skype™ to robertor
thanks, I will study.
rob
Old 14th September 2012, 11:11 PM   #252
Jean is offline Jean  United States
Jean's Avatar
Send a message via AIM to Jean
Ordered the board
left lane is for passing, slower traffic keep right please.
Old 15th September 2012, 01:34 AM   #253
Jean's Avatar
Can someone point me to a BOM for the eBay board? thanks !
Old 15th September 2012, 02:16 AM   #254
ashok's Avatar
Jean, you must have deleted your post asking about the supplier of my JLH board. I did get the message by email !
Your problem appears to have been solved. In any case, I made my own board, which isn't great. Been planning to update it as soon as I have time but want to add a protection circuit ( relay) so that just in case there is a large dc offset it shouldn't fry my expensive phones. I run my amp on +/- 12 volts and it sounds very good. The supply is regulated by LM7812/LM7912 chips.
I notice many people having severe offset on power on and the offset settling down after some time. I will check this on my amp which is a straightforward implementation of the JLH circuit. The heat sink size is critical to keep the temperature down and reduce drift. I remember seeing only low offset voltages on it. But I could be wrong.
Cheers.
AM
Old 15th September 2012, 03:17 AM   #255
Jean's Avatar
Hi, yes I just scanned through the thread and board the bare board on eBay. I think I can come up with the BOM using Miles posts, but need to know what heatsinks to order that will fit the board exactly.
I use Sony MDR-7506s as my headphones, hopefully this will satisfy me, but it is my first dedicated headphone amp. My main amp is a diy p3a based dual mono, powering my diy scanspeak 3 ways.
Old 15th September 2012, 06:18 AM   #256
oz7aff is offline oz7aff  Denmark
oz7aff's Avatar
This is the heat sinks that I have used:
12pcs Transistors TO-220 Aluminum Heat Sink | eBay
I have no BOM, but a checklist
220p
330p
0u1
2u2
100u
2200u
2V7
4007
4148
LED
7812
7912
KLEM3
CON3
KLEM2
10K TPOT
10k Vol POT
2R2
5R1
22R
100R
470R
1k
2k2
3k3
4k7
220k
2N2222
2N2907
TIP41
Heat Sink
Old 15th September 2012, 11:00 AM   #257
hotiron is offline hotiron  Scotland
hotiron's Avatar
NEW Ver JHL Class A Headphone amplifier PRE AMP KIT DIY | eBay
Just buy the board ready built Jean. Save you a lot of hassle!
If you give up easily Dont start!!
Old 15th September 2012, 11:19 AM   #258
roclite is offline roclite  United Kingdom
Send a message via Skype™ to roclite
Default Ebay JHL Headphone amp
Agree with Hotiron, far easier to buy fully assembled and tested board then remove/replace the half dozen components to make it sound great.
Best $30 i ever spent, after a few modifications of course. Recommend you keep the DC output offset bias circuit, but you need good filtering to avoid hum coupling into your input stage transistor. Follow the thread, all the information is there. Good luck with your build. Post some pics.
Old 15th September 2012, 12:28 PM   #259
ashok's Avatar
The board linked by Hotiron looks nice. But the input cap is questionable. This can affect the sound if it isn't good. You could start with it and see if other film caps are better. However they might not fit on the board and could be placed near the input RCA sockets.
At least it is some place too start !
My board just has a long heat sink ( plain 1.5 mm aluminum strip) on each side of the board. I wanted to make the new board so that it can sit directly on one finned heatsink. Need to find that heatsink first !
AM
Old 15th September 2012, 01:50 PM   #260
hotiron's Avatar
I use a Wima 2u2 "MKS2" at the input, no bypass. Sounds good. The feedback cap has a huge influence on the sound also I have 220uF Elna silmics in there.
JLH headphone amplifier steveh49 Headphone Systems 8 14th May 2014 03:31 PM
JLH Headphone amp aethelbert Headphone Systems 4 13th July 2009 11:14 PM
JLH headphone amp with FET's and servo nelsonvandal Headphone Systems 17 30th August 2008 09:26 PM
PCB for JLH amp FaTTy Solid State 0 27th March 2007 04:40 PM
Copyright 1999-2017 diyAudio
