Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 20th August 2012, 10:57 AM   #241
oz7aff is offline oz7aff  Denmark
oz7aff's Avatar
Remember that when you want to put the 2 secondaries together to form at center tap, that tey must be put in series. Check that it is right by measuring the two ends, the voltage shall be twice the value of one secondaries.
Old 20th August 2012, 01:13 PM   #242
mkusan is online now mkusan  Croatia
Thanks oz7aff,
I did measure 24V from two ends, from center tap to one secondary 11.88V, from center tap to the other secondary 12.04V. I thought that was acceptable.
Kind regards
Marko
Old 20th August 2012, 02:29 PM   #243
oz7aff's Avatar
That should be all right. The small differents in voltage is no problem.
Old 20th August 2012, 02:35 PM   #244
robertor's Avatar
Send a message via Skype™ to robertor
little big problem: he does not want to be working at 12 volts.
work perfect with 10 volt .
rob
Old 20th August 2012, 04:24 PM   #245
oz7aff's Avatar
Then he should replace the two 12V regulators with 10V models.
Ps: in my opinion it should be running on +/- 24V
Old 20th August 2012, 05:29 PM   #246
Telstar is offline Telstar  Italy
Why? Unless he has 300+Z HPs...
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 20th August 2012, 06:38 PM   #247
robertor's Avatar
rob
Old 20th August 2012, 10:52 PM   #248
oz7aff's Avatar
It is just my opinion that small amp's like this one sound better on at higher voltage.
Old 21st August 2012, 08:44 AM   #249
robertor's Avatar
the 10 k potmeter: linear or logarithmic?
thanks.
rob
Old 21st August 2012, 10:50 AM   #250
oz7aff's Avatar
thanks.
For Audio one normaly use a Logarithmic potentiometer.
If you only have a linear type, then take a look here:
ESP - A Better Volume Control
JLH headphone amplifier steveh49 Headphone Systems 7 5th September 2011 05:05 AM
JLH Headphone amp aethelbert Headphone Systems 4 13th July 2009 11:14 PM
JLH headphone amp with FET's and servo nelsonvandal Headphone Systems 17 30th August 2008 09:26 PM
PCB for JLH amp FaTTy Solid State 0 27th March 2007 04:40 PM
Copyright ©1999-2013 diyAudio
