| Headphone Systems Everything to do with Headphones |
#181 |
all of them 4k7 to 10k
it worked for me,and the caps next to 1UF should be 220uF ,and no noise |
#182 |
Aha, thank you
#183 |
#184 |
Well done. Thats a neat case. Post some more pics Please.
If you give up easily Dont start!! |
#185 |
Hi Folks,
I built JHL kit(Chinnese version from Ebay) n then i converted them to JLH(original version), after i tested the amp, stil, i don't like the soundquality of the amp(the top highs/treble rolled off and the bass is weak) so i did some mods again - VR1 10K to 100K Potensiometer - Bypassed the C1 1uF - Desoldered R1 47K, R3 10K, C1 100uF, D1(zener diode) - Replaced C3 220pF with Resistor 10K, - Replaced R5 470ohm to 1K, then i tested them and like the improvement |
#186 |
'scuse me, but your mod makes just about zero sense to me.
You now have a considerable output DC offset, roundabout +1.8 V or so. Not something I'd call particularly acceptable. And using a 100k pot will, if anything, only increase noise and distortion.How did you come to the conclusion of "the top highs/treble rolled off and the bass is weak"? What did you compare the amp to, with what kind of headphones? Have you carried out a basic frequency response test (using e.g. soundcard + RMAA)? Assuming it is equipped and working correctly, the JLH amp built according to the first schematic should have none of the deficiencies you describe. |
#187 |
Hi there,
I'd like to know if measuring the dc offset with and without load, you see any differences. because I measure around 30 mv of difference. My sensation is that DC offset is unstable, and I have some problems to fix it I changed some components: C13 = 1,5uF instead of 1uF R19= 10 K instead of 220K ((no technical choice, only for components availability ) VR3= 2,2 K instead of 10K (idem) C15 = 47pF instead of 220pF In this way I extended the range of frequency from 5Hz to 22KHz flat, could it be the cause of my problem? Thank you in advance |
#188 |
Assuming you have adjusted DC offset to 0+/- 10 mV when the amplifier is warmed up, there should be no significant influence of loading on it. I've simulated with all kinds of transistors, there never was anything more than 1..3 mV of difference to be observed. There shouldn't be one either, since your load connects two nodes at virtually the same potential.
How stable are your supplies? BTW, try finding a larger-value resistor for R19, otherwise power supply rejection at higher volume settings will suffer. |
#189 |
I changed psu stage with LM 317/337 instead of 7812/7912.
maybe cause of improvvisation wired could generated instable voltage, but don't seem me if I see the multimeter. http://ubuntuone.com/1nISGLbzDGSr0JKlJTzKrG |
#190 |
I replace the original power supply stage (7812/7912).
Now I measure the same offset. However this it instable and sensible at the change of temperature. Do you suggest me, give up the offset control and put a filter condenser in output? If you agree, which value? |
| JLH headphone amplifier | steveh49 | Headphone Systems | 7 | 5th September 2011 05:05 AM |
| JLH Headphone amp | aethelbert | Headphone Systems | 4 | 13th July 2009 11:14 PM |
| JLH headphone amp with FET's and servo | nelsonvandal | Headphone Systems | 17 | 30th August 2008 09:26 PM |
| PCB for JLH amp | FaTTy | Solid State | 0 | 27th March 2007 04:40 PM |
| Page generated in 0.11748 seconds (75.70% PHP - 24.30% MySQL) with 11 queries |
