Headphone Systems Everything to do with Headphones
JLH Headphone Amp
JLH Headphone Amp
Old 28th February 2011, 11:22 AM   #101
MilesCampbell is offline MilesCampbell  United Kingdom
CORRECTION
Also JLH did some work on stabilised power supplies
- Power Supplies for Electronic Equipment Part 2 – Shunt and Series Designs
ETI
Apr ’94 p21
Source The Class-A Amplifier Site - JLH Articles
and here
John Linsley Hood ripple Eater - Rock Grotto Charity Edition
Old 28th February 2011, 01:13 PM   #102
ADDITIONAL
hotiron in http://www.diyaudio.com/forums/headp...ml#post2450241
and
synchron in http://www.diyaudio.com/forums/headp...ml#post2461130
Seem to have this JHL Class A headphone amplifier earphone AMP / preamp on eBay (end time 28-Feb-11 12:58:08 GMT)
Which now has been modified to this
NEW Ver JHL Class A Headphone amplifier PRE AMP KIT DIY on eBay (end time 23-Mar-11 05:43:37 GMT)
These are both JLH Circuit 1 from The Class-A Amplifier Site - JLH Headphone Amplifiers
Please note that on ebay they are called JHL and to find them you will need to use the worldwide search term under advanced or the left side of the screen.
I wrote to the company in China bai(DOT)du(DOT)com(AT)hotmail(DOT)com this morning it seems the modifications between the two PCB's are layout and component quality ... In a very fast reply there was a copy of the schematic for the new version if anyone is interested. The old one is a green PCB and the new one a blue PCB.
Thought these PCB's maybe a good starting point, your comments are very welcome ?
Old 28th February 2011, 01:39 PM   #103
Hart JLH Headphone Amp - Chiara
There seems to be a third design that can be found here JLH headphone amp
The kit and PCB can be purchased here Chiara
Old 28th February 2011, 01:54 PM   #104
Although the original article is not included, two updated designs can be found
1. By Greg Gerskine here JLH Add-on Shunt Regulator
2. Rock Grotto here JLH Ripple Eater Build and Support Thread
I hope this is all helpful ...
Miles
Old 1st March 2011, 01:49 PM   #105
hotiron is offline hotiron  Scotland
hotiron's Avatar
Default K170 CCS
Oh dear I've been experimenting again.
I had to mess around a fair bit to get the bias sorted out.
R6 sets bias current 110R = > 75R = <
Ive set bias at 50ma
And its sounding pretty damn good.
Offset is stil using LM336-2.5 and a 10K trim pot.
If you give up easily Dont start!!
Old 1st March 2011, 02:09 PM   #106
hotiron's Avatar
Default Unbelievable
Hi Miles, I just had a look at Alongs new board on ebay, and could not believe he had changed the input caps to foils and then bypassed with a ceramic.
My so called JHL has been shelved.
As I much prefer my stripboard version.
Don't know if it's because of the P2P like construction or what:
Old 1st March 2011, 03:08 PM   #107
hotiron's Avatar
Default New V Old
Here is a pic of my new perfboard K170.
And on the right is the symmetrical one I built Probably about 18 years ago when it was published in ETI.
Old 1st March 2011, 03:54 PM   #108
hotiron's Avatar
Bollocks Looks like I was beaten to this. I thought i had an innovation.
http://www.diyaudio.com/forums/headp...ets-servo.html
Old 23rd March 2011, 11:31 AM   #109
muddobber is offline muddobber  United States
Hello HotIron. I too purchased the headphone amp off eBay. I was wondering if you could be so kind as to list all the parts you changed, part value and location on the board?
Old 27th March 2011, 11:18 AM   #110
hotiron's Avatar
I have revealed all here look at the pic for location.
JLH Headphone AmpHide this!Advertise here!
JLH headphone amplifier steveh49 Headphone Systems 8 14th May 2014 03:31 PM
JLH Headphone amp aethelbert Headphone Systems 4 13th July 2009 11:14 PM
JLH headphone amp with FET's and servo nelsonvandal Headphone Systems 17 30th August 2008 09:26 PM
PCB for JLH amp FaTTy Solid State 0 27th March 2007 04:40 PM
