Headphone Systems Everything to do with Headphones
Aleph headphone amp
Aleph headphone amp
Old 16th June 2003, 06:51 AM   #11
Edwin Dorre is offline Edwin Dorre  Netherlands
Originally posted by jwb
Hi Edwin. It's going well. I got a Sun 411 SCSI case to put the amp in and modified it for XLR connectors. I'm still in the process of drawing the printed circuit board. Hopefully I will finish it next weekend.
I also increased the design rail voltage to 14V.
Did you listen to it? How does it sound? What did you use before building this Aleph headphone amp?
Edwin
Old 16th June 2003, 06:55 AM   #12
swede is offline swede  Switzerland
swede's Avatar
Default Powersupply
So, how about the PS?
Are you going for an unregulated supply, or are you using a regulated?
I've been schetching on a regulated PS based on the circuit explained in the A75 article part 2, which I will use for my Aleph headphone amp.
//magnus
Old 16th June 2003, 05:11 PM   #13
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
Default Re: Powersupply
I have listened to one channel on a breadboard. It sounds rather bad! But it is powerful and the bad sound is a result of poor layout, I hope.
My previous headphone amp was the Sheldon Stokes design seen on Headwize.
I am using four separate Sulzer regulators with AD797 error amp and ZTX869 for the pass transistor. The power dissipation is low enough to not require a big power transistor.
Cheers
Old 30th August 2003, 01:03 AM   #14
jwb's Avatar
Default Case finished
These Sun 411 SCSI cases are awesome for audio projects. The SCSI connector cutout is just the right size for two Neutrik XLR jacks. And, the case comes fully shielded contains a switched, fused power entry module. What more could I ask for?
Old 30th August 2003, 01:05 AM   #15
jwb's Avatar
Images taken with my cell phone!
Old 30th August 2003, 01:17 AM   #16
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
That is a pretty good picture for a cell phone cam...
Old 30th August 2003, 07:26 AM   #17
tortello is offline tortello  Italy
tortello's Avatar
Hello JWB,
check your output offset value
Marcello
Old 30th August 2003, 03:56 PM   #18
jwb's Avatar
Hello Marcello. Output offset is trimmed to zero, unmeasurable when the amp is warmed up. Why do you mention it?
By the way, your amp is my inspiration. Very nice job!
Old 2nd September 2003, 01:25 PM   #19
tortello's Avatar
Hello ,
thanks for the compliment, but I've only turned the Pass' design into a smaller world.
In your design, the lack of a capacitor between R20 and the ground might bring about this problem, but if it works...
Very nice the "Sun Look"!!
Cheers
Marcello
Old 5th September 2003, 12:55 AM   #20
mrgreg2u is offline mrgreg2u
Send a message via AIM to mrgreg2u
hey jwb ! your amp looks great!! i want to make an aleph headphone amp. where did yo get the case, it's awesome !!! greg
Aleph headphone ampHide this!Advertise here!
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 20 7th April 2018 11:04 AM
jwb's ultimate aleph headphone amp jwb Headphone Systems 76 9th April 2013 11:01 PM
Aleph X as headphone amplifier Mickey Headphone Systems 3 25th October 2007 02:29 PM
Nice way to add a headphone amp/plug to Aleph-30? h_a Headphone Systems 10 8th February 2007 01:28 PM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
