any advice on how to match a headphone level output to valve amp input levels? any advice on how to match a headphone level output to valve amp input levels? - diyAudio
Headphone Systems Everything to do with Headphones
Old 18th December 2009, 02:58 AM   #1
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
Default any advice on how to match a headphone level output to valve amp input levels?
basically i have a single channel valve amp and i would like to use my pedal board with it to enable me to change 'channels' or FX.
The trouble is that the pedal output is a headphone level with volume pot, and i have to wind this right down to get a clean sound as the output is way too high. Only if i do this, the sound becomes very thin, and in fact the amp sounds way better on its own.
Now as the pedal board and amp are both very good IMO i would love to be able to use both together as seperately they sound great (DM signature 120 valve head, and vox tonelab se).
Im an electronic kinda guy so i have no trouble making something to go between pedal and amp input. I have considered using just a resistor to lower the output level of the pedal to the input level of the amp, but i dont know if this will do alot to change the sound. I think there is an issue with the impedance matching between the two. so would i be better off trying to match with a small signal tranformer? ARGH!!! hummmmmmmmmmmm....interference.........
ANYONE? please save me from the white jacketed mental health nurse trying to lure me into the rubber wallpapered room!!!!!!
Old 18th December 2009, 03:08 AM   #2
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Try a resistor divider - cheap and easy.
Keep the R to ground fairly low (1k or less) and it shouldn't have any negative impact on SQ.
any advice on how to match a headphone level output to valve amp input levels?Hide this!Advertise here!
Best way to match levels on sources paulspencer Analog Line Level 12 18th December 2009 03:54 AM
speaker level input vs line level question crippledchicken Subwoofers 4 17th July 2007 03:36 AM
Want to convert amplifier output to input level rkc7 Everything Else 1 16th May 2004 10:19 AM
preamp input and output levels McBain Solid State 4 31st July 2002 08:33 PM
Copyright ©1999-2017 diyAudio
