Headphone Systems Everything to do with Headphones
Help with Morgan Jones headphone amp
Old 6th December 2009, 04:49 AM   #1
trevorjn is offline trevorjn  United States
Default Help with Morgan Jones headphone amp
I usually post at HeadWize, but the forum is down so I am here for some help, if you'll have me! I just finished my Morgan Jones Earmax copy with feedback
HeadWize - Project: The Morgan Jones Mini Tube Headphone Amplifier by Chu Moy
What I want to do is put bypass caps on the headphone jack so that when I plug in/unplug the headphones there is no POP. Just wondering what a good value/rating would be for these caps. Thanks in advance for any help! Oh and the amp sounds fantastic, great detail and warmth, much MUCH better than listening plugged into my computer or iPod directly.
Old 6th December 2009, 08:00 AM   #2
azazello is online now azazello  Bulgaria
azazello's Avatar
1. Switch-on the PS, without headphones.
2. Inplug headphones after 30 sec. /U R7 will be aprox. 0 v/
3. Unplug Headphones.
4. Switch-off PS.
/You can put R7=10 kohm, instead 22 kohm/
Old 6th December 2009, 09:47 AM   #3
Stixx is offline Stixx  Germany
Stixx's Avatar
It makes me wonder why there is a POP in the first place...
I've built the same amplifier (and a few others also), and none of them exibits any noise when plugging/unplugging headphones...
Old 6th December 2009, 04:12 PM   #4
azazello, I'm not sure I undestand. In what case would I want to change the value of R7? What is the benefit?
Stixx- It's not that there is an immense pop or anything, just the normal crackle of unplugging headphones, my thinking was that I could minimize this with a cap from R and L to ground.
Old 6th December 2009, 04:29 PM   #5
azazello's Avatar
Trevorjn,
Non obligatory to change R7, but You can try....
Old 6th December 2009, 08:35 PM   #6
Anyone? I'm am changing out R7 as I type this (I did put my iron down for a second but what about the caps? If I do put them in will it negatively effect the sound?
Old 6th December 2009, 09:47 PM   #7
So with R7 at 10K when I switch on the amp with no load I see the VDC across the output go up to 50v over the coarse of about 3 seconds, then back down to zero after about 4 seconds. WTF? The output caps were totally discharged when I turned it on, could this have something to do with it?
Old 6th December 2009, 10:52 PM   #8
azazello's Avatar
If You put small cap, You will loss the bass !
The cap must be Black Gate, ELNA, Nichicon for good quality of music.
If there isn't R7, on output there is U = Ua output tube.
When You plug the headphones You will hear big PUP, and maybe You will loss Your
headphones. Thank to R7 after 30-40 sec, Uoutput will be aprox 0 !
With 10 kohm U out will go faster to 0 .
Help with Morgan Jones headphone ampHide this!Advertise here!
I meet Mr. Morgan Jones SY Tubes / Valves 44 1st October 2012 04:54 AM
Morgan Jones KT88 PP E810F Tubes / Valves 23 30th December 2008 05:33 PM
So how tattered is your Morgan Jones? Richard Ellis Tubes / Valves 8 5th January 2008 02:30 AM
Morgan Jones H/P Amp problems PLEASE HELP NotInTheMafia Tubes / Valves 13 21st January 2004 12:33 AM
MY Morgan Jones headamp. digi01 Tubes / Valves 9 25th April 2003 01:19 AM
