| Headphone Systems Everything to do with Headphones |
I made a headphone amp with two LM386 chips (one per channel) and a TL082 preamp. I know none of these pieces are that great, but they were what I had on hand and I wanted a basic "headphone get louder" device. When I first power on the amp, it sounds great*, but after a few minutes of listening with it, there is noticeable distortion that slowly creeps in. None of the components get warm to the touch. Schematic and board (made via toner transfer) are posted below. What did I do wrong?
* good enough for my ears |
#2 |
The LM386 simply isn't a good chip. Use something more modern.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#3 |
Argh. What part of the LM386 causes distortion to set in over time? Did you even look at the attachments?
#4 |
Where did you get the schematic from? How much gain does it have?
Looking at the spec sheet, the LM386 has internally set gain of 20, without using external parts. I think that a gain of 20 would be more than adequate. Remove C5,C6 and R3 (C10,C11,R6 other channel) and try again. Last edited by MJL21193; 14th November 2009 at 04:47 PM. |
#5 |
Bit hard to make out on the circuit. Is the non inverting input of the LM386 floating... it should have a resistor to ground such as the volume control.
#6 |
Your PCB shows it floating... try a 10k to ground.
#7 | |
As for the pins being ungrounded, that's a side effect of the ground plane not being drawn. To see the schematic better, click to expand it, then right-click and go to "View Image" (in FireFox). |
#8 |
hello.
have a look at the orientation of the input elco's (c3,c8). what voltreg do you use? perhaps better to read/look at........... |
#9 |
Last edited by insta; 14th November 2009 at 05:14 PM. Reason: Imageshack is dumb |
#10 | |
![]() I'm using a 7808 regulator. |
| Harman Kardon Citation 12 distort sound | vacs2000 | Solid State | 1 | 1st February 2011 12:59 PM |
| Coustic Amp-560 distort on one channel and doesnt power up on the other part. | Jeja2000 | Car Audio | 7 | 4th September 2009 04:31 PM |
| PP headphone amp | whitelabrat | Headphone Systems | 8 | 24th January 2008 01:13 AM |
| t-headphone amp | legendaryfrog | Headphone Systems | 1 | 10th October 2006 08:46 PM |
| Why does my IGC distort on very low volume settings? | Dr.H | Chip Amps | 9 | 8th September 2003 12:40 PM |
| Page generated in 0.10168 seconds (78.75% PHP - 21.25% MySQL) with 11 queries |
