Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 28th October 2009, 12:09 PM   #1
Formerly Thanh1973
Default DAO Follower vs F3 Headphone Amp
I was wondering if you guys can help me espescially Grey and EUVL.
I already have F3 boards, but after reading a few comments about the DAO follower headphone amp. I am now a bit unsure which one to build.
The people who have built the DAO follower headphone amp think it is good, while no one I know has used the F3 as a headphone amp.
It would be nice if EUVL could post his latest schematic here for reference.
Old 28th October 2009, 07:19 PM   #2
EUVL is offline EUVL  Europe
There is no latest schematics other than the TCS version that Steenoe has built with great satisfaction. There are only 3 or 4 people who have announced building the DAO, and I don't know of any of them has been using F3 for headamp. So I guess your only way to find out is to build both and compare.
The DAO suits low impedance headphones better. Optimum is below 100 ohm.
Hope this helps.
Patrick
Old 28th October 2009, 08:57 PM   #3
Hello,
what is DAO?
Ciao
Guglielmo
Old 28th October 2009, 10:58 PM   #4
Formerly Thanh1973
I hope this thread takes off.
Because you DAO follower headphone amp didn't get the attention it deserved.
Old 28th October 2009, 10:59 PM   #5
Formerly Thanh1973
Originally Posted by guglielmope View Post
Hello,
what is DAO?
Ciao
Guglielmo
Have a look at the attachments
File Type: doc A brief update on the DAO with Taylor CS.doc (27.5 KB, 270 views)
Old 28th October 2009, 11:49 PM   #6
I am not a headphone user but have wondered wouldn't a scaled down SOZ
make a good headphone amp? I know a 3 contact headphone plug wouldn't
work you would ned some type of plug with 4 contacts. Sorry just always
wondered about that.
Old 29th October 2009, 12:11 AM   #7
Formerly Thanh1973
Maybe you should build the DAO
Old 29th October 2009, 12:13 AM   #8
Steve Eddy's Avatar
Well, you could use a pair of line output transformers and common the bottoms of the secondaries and use a standard 3 contact headphone plug. The price would be the added output impedance due to the transformer's winding resistances.
Also, there are already a number of "balanced" headphone amps out there. Headroom got it started and unfortunately established the most absolutely retarded "standard" of using two full size 3 pin XLRs for the headphone connection (one for the left channel, one for the right), so you end up with a big pair of goat testicles hanging off your headphone cable.
Some "balanced" headphone amps though include a single 4 pin XLR which isn't nearly so retarded although a full size XLR is still rather stupidly large for a headphone connector in my opinion.
A 4 pin mini XLR would be preferable, though some of the DIYers and aftermarket headphone cable makers complain it's too small for their cables, some of which would be better suited for loudspeaker cables.
se
Old 29th October 2009, 08:16 PM   #9
I also have a circlotron DAO if you really want to go balanced.
Downscaling Zen v.9 for use as headamp
Patrick
Old 29th October 2009, 09:22 PM   #10
Formerly Thanh1973
Thanks Patrick
MOSFET follower headphone amplifier GRollins Headphone Systems 124 20th July 2011 04:11 PM
mu-follower hybrid headphone amplifier rjm Headphone Systems 12 4th January 2010 09:45 AM
darlington/mosfet in emittor follower / headphone amp svokke Headphone Systems 11 8th June 2005 07:19 PM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 07:47 PM
Mu follower, headphone amp? alk Headphone Systems 6 29th July 2004 05:23 AM
Page generated in 0.09968 seconds (83.64% PHP - 16.36% MySQL) with 11 queries
