Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 30th October 2009, 12:52 PM   #11
Formerly Thanh1973
LTSPICE FFT results
Not Bad!!!!!!!!!!
Old 30th October 2009, 05:13 PM   #12
EUVL is offline EUVL  Europe
It takes less time to build than to simulate.
I'd rather spend the time to listen.....
Patrick
Old 30th October 2009, 09:08 PM   #13
Formerly Thanh1973
Yes I would too.
But I am looking after a new baby, So all I can do at the moment is sit on the computer.
Old 10th November 2009, 06:45 PM   #14
I have been asked about the distortion performance of the TCS version vs DAO with original CCS. Apparently simulation gives better results with the CCS than the TCS.
The idea of the TCS is to modulate the lower current source so as to provide more current drive, as well as cancel most of the even harmonics (when done right). The circuit values published were NOT based on simulations, but actual measurement of devices (LU1014s) under near-working conditions (bias, Vds, temp, etc.).
But if you would take Steen's well documented review, then there is little to choose between the two. So I would only say, build both and decide for yourself which one suits you better.
Patrick
MOSFET follower headphone amplifier GRollins Headphone Systems 124 20th July 2011 04:11 PM
mu-follower hybrid headphone amplifier rjm Headphone Systems 12 4th January 2010 09:45 AM
darlington/mosfet in emittor follower / headphone amp svokke Headphone Systems 11 8th June 2005 07:19 PM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 07:47 PM
Mu follower, headphone amp? alk Headphone Systems 6 29th July 2004 05:23 AM
Page generated in 0.07583 seconds (70.13% PHP - 29.87% MySQL) with 11 queries
