| Headphone Systems Everything to do with Headphones |
Hello all,
I've searched and can't find an answer (that I understand) for what I want to do. I have a tube preamp (a grounded grid based on Bruce Rozenblit's design) that uses 3 12au7s. The output impedance is 200 ohms. I would like to add a simple headphone output - it doesn't need to be world class high end (or even tube based), but should give a clean, pure faithful reproduction of the sound. A small circuit would be best. The headphones I want to drive ar 32 ohms, though I may change those in the future. Can someone suggest a simple design I could drop in? I'm guessing this would be something that would piggyback off of the (single ended) outputs, but the whole impedence matching thing is where I have my concerns. Thanks in advance for any help on this. Aaron |
#2 |
#3 |
Right - I was looking exactly at those. But in terms of hooking up to my pre, is the input for any of these (for example) just the single ended RCA outputs? Do I have to be concerned with any impedance (mis)matching?
I know this is going to pretty simple conceptually, I just don't want to screw anything up. It is only recently that I've had a need for listening via headphones and, since I have space in my pre chassis, thought it would make sense to add an additional output there. Thanks! Aaron |
#4 |
I have exactly the same problem. I intend to use BUF634T or similar opamp buffer. The output voltage swing of my tube preamplifier is more than enough for driving the headphones, so I need just current driving and low impedance output. My problem is that I have +12V non-regulated only, and I wanted to avoid input/output coupling capacitors. Any ideas?
#5 |
audio signal interfaces are usally not matched impedance
typically the source output is expected to be low Z (0 to ~1K Ohm) and the input to the next device is usually >10K Ohms audio signal caps can be fine and the "simplest" way to get AC gnd in a single supply amp, non-polar/bipolar Al electrolytics are the best for the larger values required to keep headphone output Rload*C corner frequency <<20 Hz - otherwise you need some sort of active supply splitter circuit |
#6 | |
This is the basics of audio . So do connect the headphone amplifier without any concern regarding impedance . - a typically input is expected at around 10K - a typically output is expected at around 600ohmi
There are not better tube than 6P3S and 6N2P for my ears ! Last edited by danzup; 2nd October 2009 at 07:37 AM. |
| Class D amplifier with tube preamp on input any ideas | jazzman06 | Class D | 9 | 4th July 2009 11:44 PM |
| tube microphone preamp design ideas | PRNDL | Tubes / Valves | 9 | 7th June 2008 05:43 PM |
| Add headphone output to preamp | whitelabrat | Headphone Systems | 2 | 24th January 2008 07:36 PM |
| Octal tube as headphone amp output tube | yagoolar | Headphone Systems | 6 | 25th November 2006 09:11 PM |
| Tube Phono Preamp/Headphone Amp | trustalbini | Headphone Systems | 6 | 14th April 2003 01:41 PM |
| Page generated in 0.09927 seconds (75.69% PHP - 24.31% MySQL) with 10 queries |
