Headphone Systems Everything to do with Headphones
HA-2 Wheatfield headphone amp query
Old 11th August 2009, 05:15 PM   #1
Brit01 is offline Brit01  United Kingdom
Default HA-2 Wheatfield headphone amp query
Have a quick question regarding this design.
Does the cathode resistor of the 6AS7 CF output stage need to be bypassed?
I assume yes as it shows 2 links to ground off the cathode resistor of 2K 20W.
http://www.pmillett.com/Wheatfield/manual.pdf
Old 11th August 2009, 06:25 PM   #2
DougL is offline DougL  United States
No,
Bypassing that resistor would effectively ground the output for AC.
The grounds shown are probably unused pins on something.
HTH
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 11th August 2009, 06:30 PM   #3
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
That resistor is labelled as a TO-220 device, so I guess there are probably 4 pads on the PCB for it, and the middle 2 should be grounded.
There are still unbridgeable divisions between cultures. How can two peoples ever come to understand each other when one of them is ignorant of Totò? Umberto Eco
Old 11th August 2009, 06:30 PM   #4
Thks Doug. That makes sense.
Old 11th August 2009, 07:03 PM   #5
whitelabrat is offline whitelabrat  United States
whitelabrat's Avatar
no bypassing on that 20w 2k resistor. i used a 25w, thermal grease, and an el grande heat sink. that sink gets hot too, but not painful.
i'm having a real bear of a time hunting out some bad hum on mine. i'd suggest avoiding the 200 series hammond transformers like the plague. mine has some serious mechanical noise.
Old 11th August 2009, 07:33 PM   #6
Thks for the heads up. I've got a couple of 2.2K 20Watts I was going to try. Maybe attach them to a heatsink I've got hanging around.
Old 11th August 2009, 07:46 PM   #7
What current are you running your tubes on? I was hoping I could use a little less B+.
I plan to use 6080's.
I see he's using about 95 mA.
Old 11th August 2009, 08:20 PM   #8
I could probably get about 240/250 B+ out of my transformer with max 200mA.
psu (275V secondary, 52ohms): (CRCRC)
100uf
225 ohms
470uf
225ohms
470uf
Old 11th August 2009, 08:25 PM   #9
leadbelly's Avatar
100 uF is too big for a tube rectifier.
Old 11th August 2009, 08:28 PM   #10
Sorry leadbelly forgot to mention I'm going to use a SS power supply.
And yes you are very right. I use 0.47uF in my tube rectifiers.
HA-2 Wheatfield headphone amp queryHide this!Advertise here!
UK Law query john blackburn The Lounge 35 15th May 2009 09:59 AM
query Professor smith Multi-Way 2 5th May 2009 01:47 AM
query on the PSU of a preamp ray_ben Tubes / Valves 2 1st January 2006 10:40 PM
BOZ query to chocky JC Fardo Pass Labs 1 21st December 2005 06:21 PM
Clock query Horn_aficionado Digital Source 5 2nd January 2004 06:35 PM
