Headphone Systems Everything to do with Headphones
JLH Headphone amp
JLH Headphone amp
Old 12th July 2009, 07:45 PM   #1
aethelbert is offline aethelbert  England
Unhappy JLH Headphone amp
Hi all,
I'm building a JLH headphone amp, circuit1 in this article-
http://www.tcaas.btinternet.co.uk/jlhphones.htm)
I'm wondering if anyone here has any experience with it.
So far one channel is built but not working . I'm pretty sure that the circuit is ok. I've substituted BD139 and BC547/557 transistors.
Power supply is from a 24V DC unregulated wal wart to a standard LM317 regulator circuit. This is tested and working fine, giving 24V DC out.
Now this is where I think the problem is and I'd appreciate some advice. I used a circuit snippet from the Chu Moy article at headwize (fig 3).
http://headwize.com/projects/showfile.php?file=cmoy2_prj.htm] http://headwize.com/projects/showfil...=cmoy2_prj.htm[/URL]
This is to give a split supply, +/-12V in this case. Unloaded it looks fine but hooked up to the amp I get something like 13.5V on one side and 9.5V on the other.
I think the impedences are interacting and throwing the voltages out of kilter. Any workarounds for this or else I need to start again with the power supply.
Also- the diagram shows no cap on the output- won't this put DC on the headphones?!
Old 12th July 2009, 09:40 PM   #2
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
JLH Headphone amp
I think the JLH-amp draws more power than the voltage splitter can supply, hence the imbalance - in this case 2x12V is not the same as 24V. You need a "proper" split supply with a dual-wound or centre-tapped transformer to make it work. If you only have a single transformer (note: must be AC) you can use a voltage doubler circuit (example here: http://sound.westhost.com/project05.htm)
/U.
Old 12th July 2009, 10:35 PM   #3
jaycee is offline jaycee  United Kingdom
As said above, it's not going to work with a simple potential divider to power it, especially as it's class A. You need to make a split supply using LM317 and LM337.
You'd also want a wallward with a fair bit of current. It's probably going to be better to use a transformer. A 30VA unit should do. Get a 2x15VAC one and that should work great.
Old 13th July 2009, 07:37 PM   #4
Since as you have no email button, im curious, where about in Norwich are you? You can e-mail me privately if you wish. It'd be nice to know someone local with the DIY passion too
Old 13th July 2009, 11:14 PM   #5
thanks for the responses. I was hoping not to have to build a "complex" power supply, partly for ease and partly for lack of parts and a small budget. Guess I'll have to have a rethink!
I'd like to hear any comments on the performance of the circuit if anyone has anything to say on that too.
Jaycee, I'll email you.
JLH Headphone ampHide this!Advertise here!
Another DAC + Headphone amp ghetto Digital Source 14 10th July 2008 04:02 PM
Using a headphone amp as a pre-amp? Basalt Solid State 4 19th November 2007 09:55 AM
ESL Headphone X-former bjackson Planars & Exotics 5 19th September 2005 03:45 AM
Headphone amp audioPT Headphone Systems 3 20th September 2004 10:17 PM
Zen v4 headphone amp Rob M Headphone Systems 11 21st May 2003 12:58 AM
