Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 11th July 2009, 02:56 AM   #11
ncc is offline ncc
Send a message via Yahoo to ncc
Originally posted by rman
I built this regulator.
http://www.glass-ware.com/tubecircuits/High_Voltage_Regulator.html Broskie regulator
It didn't work... at least I couldn't make it work.
Cheers.
I know at least one man who could make it work, see:
Here is his main site:
a very infomative site that I like very much
Cheer
Old 11th July 2009, 04:00 AM   #12
rman is offline rman  Canada
rman's Avatar
Hi ncc.
From the page of your second link:
There is a 1µF capacitor connected across the load resistors, I found that with a purely resistive load the regulator will not 'power up'.
Maybe that was my problem when trying to test it!
I still have this thing laying around, should check it over and try again.
Cheers.
Old 14th July 2009, 05:28 AM   #13
rman's Avatar
After rechecking the board I found a missing connection after about a minute. Months ago when I built it, I couldn't find the flaw. It regulates voltage alright. will have a look with the scope tomorrow.
Old 14th July 2009, 06:38 AM   #14
ncc is offline ncc
Hi rman,
Nice to hear that you've found the error
This regulator use a floating power supply for the reference voltage and error amplifier, I've experimented with this regulator by using a RC filter then a regulator (a LT3080) for the floating power supply, after that, high voltage output of the regulator is much cleaner than the original design.
Cheer
Old 15th July 2009, 02:28 AM   #15
rman's Avatar
hi ncc.
Great idea! Regulating the op amps supply makes a lot of sense to me as most op amp supplies are regulated.
Well, I had a look at the output and it is oscillating quite nicely at about 3 MHz, 0.3v pp. I put in a larger gate stopper (1k) as close to the gate as I could get. This only distorted the 3 MHz waveform.
The load for this test is a big wire wound pot set to 12.5k (20ma. @250v). It was intended for a phonostage, the regulator that is. Interestingly, when the load is adjusted to about 12.1k, the oscillation stops. The Mosfet is an IRF BC40 (found on shop floor at work). swapped in an IRF 540 and the amplitude of the oscillation rises. I really don't' know enough to account for all this. I can only conclude that layout is critical, and that mine is not great.
I guess we have hijacked this thread as the original topic seems to have disappeared.
John Broskie Aikido boards Original Burnedfingers Tubes / Valves 1 12th October 2010 08:57 PM
Beam pentodes and suppressor-grid pentodes of same type jon_010101 Tubes / Valves 3 2nd May 2009 11:18 PM
Design using EL42 output pentodes phil_2 Tubes / Valves 61 13th November 2008 11:10 AM
John Broskie's enhanced T8 CarlyBoy Tubes / Valves 13 8th October 2006 06:13 PM
Where is John Broskie ? reinhard Tubes / Valves 7 8th October 2002 01:27 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
