Headphone Systems Everything to do with Headphones
Interesting: P-amp Headphone amp from Grey Rollins
Old 3rd July 2009, 05:05 PM   #1
promitheus is offline promitheus  Europe
promitheus's Avatar
Default Interesting: P-amp Headphone amp from Grey Rollins
I just found this article:
http://www.enjoythemusic.com/diy/0709/p_amp_v1.htm
Has anybody built it?
What is your opinion?
the parts are relatively cheap but I donīt know the J271 Jfets.
Question for Grey Rollins if he is reading this.
is it possible to build the amp without matched parts for testing?
Old 21st July 2009, 04:50 AM   #2
chrismercurio is offline chrismercurio  United States
chrismercurio's Avatar
bump...read the article
Old 21st July 2009, 08:36 AM   #3
h_a is offline h_a  Europe
h_a's Avatar
Thanks for the link!
For a quick test you can completely ignore jfet matching, it's anyway way overrated. If you're happy with your amp and want to get the most out of it, you can match the differential.
If you feel bored, match the rest.
Have fun, Hannes
High Octane phono preamp Wiki
Old 21st July 2009, 04:19 PM   #4
ALERT: Dumb question below:
Since the power dissapation is so low, is any heatsinking required? Or can this all be done point to point on a breadboard with no heat sink and simple wall wart supply?
Chris
Old 21st July 2009, 05:44 PM   #5
jcx is offline jcx  United States
I don't see the point unless you're acutually helping Grey use up his excess stock - if you're going to buy parts why not something like:
http://headwize.com/projects/showfil...lmore3_prj.htm
TO-92 plastic transistors are usually rated 600mW free air pwr dissipation - good engineering practice would be to only use ~1/2 that
Old 21st July 2009, 06:04 PM   #6
What headphones do you use? with what amplifier? Are there other amplifiers that you like more than the above?
Old 21st July 2009, 06:47 PM   #7
Default Op Amps not discrete
I have a range of headphones including HD600, K701, SA5000 and most recently Koss ESP950 electrostatic
I've built my own unusual high feedback composite op amp based amps for the dynamics:
http://www.diyaudio.com/forums/showt...58#post1392458
more pics:
http://www.head-fi.org/forums/f6/ad8...8/#post2263321
some composite circuits (conceptualy related to what I used in my amp)
http://www.diyaudio.com/forums/showt...806#post512806
I hope to design/build a high gain composite SS amp for the electrostatics as well - looking at optocouplers cascoded with IXTP01N100 running Class A for the high V
Old 21st July 2009, 07:07 PM   #8
I like your heatsink. Reminds me of the DIY section of a PC store.
Interesting: P-amp Headphone amp from Grey RollinsHide this!Advertise here!
TI headphone amp with interesting possibilities FastEddy Headphone Systems 53 5th August 2014 07:54 PM
beta22 - a real interesting headphone amp peranders Headphone Systems 8 10th January 2009 04:53 PM
Grey noise angel Everything Else 7 12th August 2005 04:14 AM
Where is Grey Rollins? jam Everything Else 10 7th April 2002 04:43 PM
