Simple Headphone Distribution Amplifier - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 15th April 2009, 02:49 PM   #1
Default Simple Headphone Distribution Amplifier
Howdy everyone,
So, I built a simple little headphone distribution amplifier. It's based around two OPA4227's (a lovely chip, incidentally - why do stereo opamps put V+ on the opposite side to Pin 1?). I could knock up a full schematic if anyone wanted it, but it's a pretty standard sort of topology, consisting of:
- An inverting buffer
- Output split to two volume pots, each of which feeds
- An inverting gain stage with a gain of 10
- And finally, the two outputs.
The gain stage needs to be inverting so the volume pots don't interact with each other. The buffer is thus made inverting to restore the original phase.
Those counting will find that I have two opamps remaining, so each of the two outputs was given its own actively driven ground "channel".
Old 15th April 2009, 02:51 PM   #2
The power supply section is provided by a TLE2426 along with a 470uF capacitor from each rail to the virtual ground.
The "sandwich" construction I employed makes it hard to see what's going on, but here's a pic down the side that gives a bit more of an idea.
Old 15th April 2009, 03:11 PM   #3
AndrewT is online now AndrewT  Scotland
Default Re: Simple Headphone Distribution Amplifier
could it be anything to do with the 741 being able to be reversed in it's socket and survive. This might have been very important in the early days before we all became familiar with ICs.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 6th January 2010, 10:52 PM   #4
By request, here's a schematic of the amplifier section, expanded to show 3 outputs.
Old 27th October 2010, 01:20 AM   #5
any thoughts on whether you could have multiple sources "mixing" into each channel of output?
I'm looking for a monitor mixer for headphones, multiple inputs with individual control for each output
example- recording 4 piece band with vocals- drummer wants more bass and vocals, keyboardist wants guitar, a little more bass, and vocals, but less drums, guitarist wants more guitar and vocals with everything else equal in the background, bass player wants more kick drum and vocals
Peavey used to make a monitor mixer for just such monitor mixes, but they were big boards, each instrument came into the board and there were 8 level controls each sending to 8 'sub masters' so the outputs could send a different mix to a possible 8 monitors... I want something similar (4 sub mixes would be fine) for headphones. Unlike a standard analog mixer with sub buss out the monitor mixers had greater control-
Old 27th October 2010, 10:38 AM   #6
post4.
Do you realise that u1 is trying to drive a load just slightly higher than 1k1?
That will need to be a mighty opamp to perform well with that load.
A gain of 10 for a headphone seems far too high.
regards Andrew T.
Old 26th November 2010, 06:33 PM   #7
paulb is offline paulb  Canada
Originally Posted by AndrewT View Post
post4.
...A gain of 10 for a headphone seems far too high.
Depends. I found my Sennheisers (300 ohm) need some gain from a typical CD player, or from an ipod. Gain of 10 would be more than enough, but it's not 'far too high'.
Old 28th November 2010, 11:08 AM   #8
TzeYang is offline TzeYang  Malaysia
it's a bit too high by today's "style".
I have the HD650 and I can live with unity gain.
How to build audio distribution amplifier? lovelikecute Instruments and Amps 13 15th August 2013 06:55 PM
Balanced audio distribution amplifier vlade Solid State 3 20th October 2008 11:31 AM
headphone distribution amplifier dubline Headphone Systems 2 17th September 2008 11:01 AM
Simple Headphone Amp Nico Ras Headphone Systems 69 8th August 2008 12:19 AM
A simple Headphone amplifier. Kapibara Headphone Systems 3 20th July 2007 08:55 AM
Copyright 1999-2017 diyAudio
