Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 22nd June 2009, 11:48 AM   #21
sparkle's Avatar
pic's no2.
tube part without coupling cap's...
Old 22nd June 2009, 11:50 AM   #22
sparkle's Avatar
no3.
psu for tube stage.....
very simple...
Old 22nd June 2009, 11:56 AM   #23
sparkle's Avatar
i mean - this is very strange - 100uF is not enough as a coupling capacitor...
when i was using only a buffer (without the tube part) the frequency range was perfectly o.k.... now.. it is not enough - what is happening there???
it seems like the input resistance of the buffer is a lot lower than it should be......
ohhh... btw - i just remebered..... i have a capacitor over a cathode resistor of the tube - it is 220uF capacitor - i have to check if that one is big enough...
Old 22nd June 2009, 12:09 PM   #24
sparkle's Avatar
o.k. - i tried also to change the cathode capacitor to a 550uF value - almost no change in the bass segment....
so it seems that the coupling cap between the tube and mosfet stage is not nearly enough like it should be ...
Old 22nd June 2009, 02:52 PM   #25
sparkle's Avatar
it looks almost like the tube stage is driving the mosfet stage that has an input impedance of 15-20R... how about that???
Old 23rd June 2009, 02:52 PM   #26
sparkle's Avatar
oh yes... it was sooo dead....
buffer was dead - i assume that the tube burned the mosfet because i didn't put any zener diodes between gate and source... idiot....
anyway.. i tried 12B4 part alone .. it drives the headphones like a charm - no problem ... 20mA, Ug=10V, Up=106V.... perfect... sound is powerfull and detailed... very clear... i will remove the buffer for now and make it with 12B4 only.... it works nice....
MOSFET follower headphone amplifier GRollins Headphone Systems 124 20th July 2011 03:11 PM
HLLY MK III 3 Vacuum Tube Headphone Amplifier Pre Amp hllyelec Vendor's Bazaar 2 19th July 2009 05:54 AM
A Tube Hybrid Headphone Amplifier TzeYang Headphone Systems 5 10th September 2008 11:22 PM
single mosfet headphone amplifier question Jean Headphone Systems 8 23rd June 2007 11:50 PM
Sennheiser HD-580 with OTL tube headphone amplifier Nixie Swap Meet 1 27th February 2007 11:40 PM
Page generated in 0.08649 seconds (73.68% PHP - 26.32% MySQL) with 11 queries
