Headphone amp issues again - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 5th January 2009, 03:57 PM   #1
jman 31 is offline jman 31  United States
jman 31's Avatar
Default Headphone amp issues again
Alright I'm back again. I finally built a headphone amp that I am extremely happy with. It works great except that when I run through the distortion circuit it doesn't distort! I am afraid that I have left out a key component or something. If anyone would be so kind as to look over this circuit and see if I'm missing something I would greatly appreciate it! Everything works great otherwise, so I assume it's only the distortion circuit that is giving me problems.
Jeremy
Old 5th January 2009, 05:29 PM   #2
Minion is offline Minion  Canada
It should distort if you have the chip set up for enough Gain...The Diodes should start clipping when the output reaches 0.7v , the problem with this is that the output will be of really low Volume as 0.7v output is a very low Volume (Barely Line level) so a Makeup Gain section would be good to get the Volume higher...
If you put a 10uF cap between pin 1 and 8 it will set the gain to 200 which should be enough to start clipping...or put a Pot in series with the 10uF and you get adjustable gain...
Cheers
Old 5th January 2009, 06:27 PM   #3
jman 31's Avatar
Thanks again minion! As always, you are very helpful! I will give that a try and report back.
Old 5th January 2009, 06:50 PM   #4
jman 31's Avatar
OK, I tried that. No dice. I even tried a 33uf cap I had laying around. Does it matter if its a polarized or non poarized cap?
it's really loud but no distortion. Even with the guitar pot volume at 1 it is really loud. do you have any ideas for a simple distortion circuit that would work better or take less gain?
Old 5th January 2009, 07:11 PM   #5
Well Try a clone of the DOD250 and put the LM386 curcuit after it with a lower gain....
http://www.generalguitargadgets.com/...ist_250_sc.pdf
it is pretty much simular 2 your curcuit but uses a regular opamp...
Old 5th January 2009, 07:38 PM   #6
mjf is offline mjf  Austria
hallo.
distortion should beginn at a( low) level of 0,6v .
perhaps there is something wrong with your connection of the parts(missing connection of the diodes or so.....),or the switch(you need only one switch : s2=effect on/off,s1 can be closed always........).
greetings.............
Old 5th January 2009, 08:18 PM   #7
jman 31's Avatar
Originally posted by mjf
hallo.
I have checked all of the connections and went as far as to change the diodes to some IN914's. Everything checks out with with a meter, as far as continuity and the diode seem to read right. When I get a chance I will measure the output voltage to see if I am anywhere near the .6v required for the diodes.
The switches are in order although I understand what you are saying about one switch. I am getting good output through the distorted circuit, it just isn't distorted.
Jman
Old 5th January 2009, 08:30 PM   #8
what kind of headphones do you use?
high impedance,600 ohm or so.
or low imp. 30 ohm...........
greetings.........
Old 5th January 2009, 09:26 PM   #9
jman 31's Avatar
All of the headphones I have are low impedence between 24 and 44 ohms.
Old 5th January 2009, 09:37 PM   #10
jman 31's Avatar
The problem that I am trying to work around is space. I am trying to keep the circuitry as minimal as possible to fit it in a very confined little box. I have a bunch of regular components available so I am trying to avoid buying surface mounted items. And I'm using half of a premade perf board from Radio Shack
NAD 216 issues Kamuy Solid State 28 17th December 2009 04:16 PM
WAF issues Lostcause Full Range 15 17th August 2008 04:21 PM
IP issues GRollins The Lounge 25 10th July 2007 06:43 AM
CFB Issues Fuling Tubes / Valves 12 23rd August 2005 08:34 PM
Copyright ©1999-2017 diyAudio
