| Headphone Systems Everything to do with Headphones |
#11 |
If you are looking for Grado specific transformer coupled amps, try these from my website:
This one is almost the exact same amp as audiodesign's http://www.ecp.cc/semha.html And this is the improvement: http://www.ecp.cc/SSS.html These are parafeed designs: http://www.ecp.cc/less-pressivo-plus-plus.html http://www.ecp.cc/less-pressivo-plus.html and this one I posted to Headwize two days ago: http://headwize.com/ubb/showpage.php?fnum=3&tid=7627 Also, member Kevinkr has a WE417 - 71a design floating around that is worth looking into.
http://www.ecpaudio.com |
#12 |
This could be the schematic.
An Rout about 14ohm is not the top to drive 32ohm but there is no better design using a single tube on single ended design. The D3A is the unique tube with a very low anodic resistance and enough voltage gain. |
#13 |
Your time is appreciated! I'll try this out.
dsavitsk I checked out your page as well. There is always so many choices! |
#14 |
Maybe feed it with a pair of 0B3's for 180v. I've been looking for a reason to use some glow tubes...
#15 | |
#16 |
I saw some NOS d3a's so I picked them up. I figured I could use the same supply as in my Tube buffer which put out ~250v. Put a pair of 0B3's bypassed with a .o1uf cap after the last RC for 180v and a nice glow
If 4 Vrms is too much is there a simple way to bring it down a bit? Could I use my buffer for the volume control or should I put a pot in it and run it straight from the source? |
| Tube-Mosfet Single-Ended Amplifier! | Matthewong | Solid State | 15 | 2nd October 2008 05:13 AM |
| ino, a possible single-ended push pull amplifier | st r | Pass Labs | 5 | 9th September 2006 06:05 PM |
| Power supply for Single Ended Amplifier | kmtang | Tubes / Valves | 20 | 27th June 2005 03:46 PM |
| has any one done this amplifier, i like single-ended | john-china | Solid State | 8 | 19th January 2004 07:43 AM |
| Page generated in 0.09975 seconds (71.08% PHP - 28.92% MySQL) with 11 queries |
