Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 17th November 2008, 01:58 PM   #1
Default lm4780 Class A headphone amp
I got a bunch of lm4780 in a trade,now I'm trying to find something to to with them. Because of the small"est" heat transfer area,I want to stay away from anything high powered,so a headphone amp comes to mind.
I want to make it fairly simple,maybe a 4780 in the feedback loop of a smaller op amp(class A biased) or maybe run just the 4780 into class A and deal with the high gain some other way.
Any Ideas would be helpful.
Old 17th November 2008, 04:41 PM   #2
The heat isn't as much of an issue as you would think for "normal" music listening. I have an amp that consists of a pair of LM4780s running in bridged mode at 25V (approximately 100W each). Both channels are sharing a heatsink mounted inside my enclosure and cooled without a fan, and it doesn't change temperature noticeably between idle and "normal" listening levels (about 40 C).
Old 17th November 2008, 06:36 PM   #3
Redshift187
What size are your heatsinks? So,a class A headphone amp should do fine with a small heatsink.
I tried a google search but I got nothing.
Old 17th November 2008, 08:59 PM   #4
It's about 5cm x 5cm x 20cm. There are only about 25 fins.
Class A, DHT driven, headphone amp ikoflexer Headphone Systems 100 26th March 2011 02:54 PM
Class A Headphone Amp solid Headphone Systems 10 8th May 2009 10:12 AM
DC Offset on Class A headphone amp. Dxvideo Headphone Systems 44 21st July 2007 08:35 AM
Page generated in 0.06736 seconds (69.14% PHP - 30.86% MySQL) with 10 queries
