Headphone Systems Everything to do with Headphones
Bass Guitar Headphone Amp?
Old 12th November 2008, 05:22 PM   #11
wxn is offline wxn  Lithuania
wxn's Avatar
LM386 has naturally low input impedance - about 50k. You need at least 200k.
So looking at (http://headwize.com/projects/showfil...guitar_prj.htm), change R1a to something like 250k-1M (100k is NOT ok) and put a voltage follower [or a simple gain stage] between R1a and R2. Any decent opamp will do, but as pointed out, FET input is more suitable.
http://ourworld.compuserve.com/homep...t/elect254.htm
http://ourworld.compuserve.com/homep...t/elect253.htm
Nothing is as simple as it seems
Old 13th November 2008, 01:50 AM   #12
jman 31 is offline jman 31  United States
jman 31's Avatar
Thanks guys, I'll look that stuff over and try to decide the best route. I will also post up the schematic as soon as I get a chance for the one on headwize that I was looking at.
Old 13th November 2008, 05:48 AM   #13
davidgale is offline davidgale  Latvia
try this one easy-to-assemble FET preamp:
http://www.hawestv.com/amp_projects/...fetpreamp2.htm
i am beginner in electronics and have built one using 2N3819 FET. maybe it does not have enough gain to act as headblowing headphone amp, but it does a very nice job as a DI box. also i'm sure that it can be modified for use with potentiometer to adjust gain.
also note that bass/guitar produces mono output. but your headphones are stereo. and if you end up using single channel amp you have to connect output of the amp to the left and right channel leads on the stereo jack to produce pseudo stereo sound. otherwise you will hear the sound coming only from one of the cans.
Old 13th November 2008, 11:57 AM   #14
jman 31's Avatar
I changed this curcuit to reflect the changes you suggested. What size would the resister in the purple box need to be if I use a 250K ohm pot? And did I do it right? I have some extra LM386 IC's that I would use for IC3.
Old 13th November 2008, 01:47 PM   #15
wxn's Avatar
You did it right. And you can omit the resistor, it is not necessary in the case. And you can't use another LM386 for the buffer - that would defeat the purpose. You need something like TL072 there.
Oh and I forgot to mention that you'll need virtual ground for an opamp to function correctly. Like in this circuit:
http://ta2020.huuryuu.com/ChuMoy_e.html
Old 13th November 2008, 07:48 PM   #16
jman 31's Avatar
Alright guys, I was digging through my stash and I came across a LF353N Dual Bifet Op amp. Will this work for the type of amp I want to build and what would be the best schematic to use if It will work. I am once again thoroughly confused as to which way to go, but I don't want to rush in and have to build it twice. Thank you so much for the suggestions so far!!
I also have a JRC4558 DX that I could scavenge out of a stereo receiver if that would be a better choice. Otherwise I'm back to ordering more parts.
Jeremy
Old 16th November 2008, 12:29 AM   #17
Zigis is offline Zigis  Latvia
Hi jman 31,
shematic you posted is not too smart for guitar. Pot in input for instrument is bad idea.
Better way - take simple Cmoy shematc with 10K volume pot, and before pot put input buffer ( take first opamp schematic from your posted schematic without pot, input directly to opamp's +in, R- 1Mohm).
you don't need any caps in signal path, guitar have not any DC on output.
if you need amp for guitar only, you don't need stereo, use one dual opamp - one half for bufer, other for Cmoy amp itself, connect output to both phones.
if you need "universal" amp, use dual opamp for Cmoy part and other one channel opamp for buffer.
Good luck!
Zigis.
Old 17th November 2008, 11:57 PM   #18
jman 31's Avatar
Originally posted by Zigis
Hi jman 31,
Good luck!
Zigis.
Thanks for the input, but you have got me more confused now. I am very visually oriented. I will sit down when I get a chance and work up a schematic for what I think it is you are saying.
Am I getting it right that you are saying to use the LF353N Dual Bifet Op amp that I have as the amp, and one of the LM386 op amps as the buffer that wxn was trying to explain?
Old 18th November 2008, 04:51 AM   #19
TheSeekerr is offline TheSeekerr  Australia
Other way around - you need high input impedance for the buffer, so use the Lf353 opamp there (BTW, why scavenge opamps? They're cheap....), and then use the 386 for amplification duties.
Old 18th November 2008, 11:43 AM   #20
jman 31's Avatar
I'm not scavenging the dual op amp, I have a brand new one. I just didn't want to pay shipping on a $2.00 op amp if what I have will suffice. If it won't then I will order another one. And I ordered 8 of the LM386's before I got an answer on my first post because I was in too much of a hurry. I guess I'm just being a cheap ***, but I'm trying to use up some of the surplus that I caused myself!
Thanks for the info. That will help when I draw the schematics.
Jeremy
Bass Guitar Headphone Amp?Hide this!Advertise here!
4x12 Guitar cab using guitar and bass speakers help andrewskaterrr Instruments and Amps 15 23rd April 2009 11:43 PM
Guitar Headphone amp with distortion schematics jman 31 Headphone Systems 7 3rd March 2009 02:10 PM
Latest guitar headphone amp...slight problem jman 31 Headphone Systems 12 18th December 2008 08:06 PM
any electric bass players? im building a bass guitar cab KOA Instruments and Amps 27 30th April 2007 03:49 PM
Bass guitar headphone only amp oldhernace Headphone Systems 1 14th July 2005 04:33 AM
