Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 12th December 2011, 11:35 AM   #391
Very Cool,Wachara.
I like the wood cans !
Are those single or dual Diagphrams?
jer
Old 12th December 2011, 12:19 PM   #392
chinsettawong's Avatar
็Hi Jer,
This is the first time I make the housing using wood. Actually I didn't quite like using wood, because it tends to absorb moisture in the air. Where I live here can be very humid. We'll see.
The drivers are single diaphragm.
Wachara C.
Old 14th December 2011, 01:18 PM   #393
I finally found a headband for the drivers. They do sound really nice.
Old 23rd December 2011, 02:32 PM   #394
I've made a slight modification to the headphones so that they are now able to accommodate better full size ear pads from Hifiman He-5.
Old 29th December 2011, 07:19 AM   #395
Really nice work chinsettawong!
What would be nice is a step by step compendium of the assembly process.
You know, cut and etch this, spray that, glue this.
Old 22nd February 2012, 12:04 AM   #396
Read this and the similar thread over at DIY Audio and I think I might have to have a crack at a set. Spent the evening on Sketchup and have began designing the stator and spacer.
Ever so slightly ripped off from one of chinsettawong's designs. Do they seem ok so far? They're both 90mm in diameter so you have an idea of scale.
Old 27th February 2012, 03:46 PM   #397
Hi Nixon,
I can't see your photos.
Wachara C.
Old 12th March 2012, 02:21 PM   #398
Just finished another pair of headphones last weekend. This time I made them with 80 cm active diaphragm diameter. The size is very much the same as Stax O2.
Yea, I know that I need better cables.
Wachara C.
Old 12th March 2012, 02:25 PM   #399
Very Nice,Wachara C. !!!
jer
Old 12th March 2012, 02:51 PM   #400
mwmkravchenko's Avatar
Are you noticing a difference in sound quality or efficiency with the larger diaphragms Wachara?
And as for the esl on a horn, I do design work for Volti audio and I am currently 90% of the way through a planar driven mid tweeter horn coupled with a bass horn that I'm calling the Klipsch killer. Goes considerably lower and cleaner than anything else I have been working with for quite a while.
Sorry for the off topic post Wachara!
Mark
Never made anything before Moondog55 Chip Amps 5 3rd September 2007 02:45 PM
Where to have PCB's made? mirzametica Parts 5 24th July 2006 06:31 PM
Home Made Tubes?? has anyone made one, is it possible?? John Biles Tubes / Valves 7 11th December 2005 01:29 AM
i made it...!!!!!!!!!!!!!!!!! tbla Everything Else 21 20th December 2002 04:46 PM
Page generated in 0.08261 seconds (71.21% PHP - 28.79% MySQL) with 11 queries
