Headphone Systems Everything to do with Headphones
Has anybody made an ELS headphone?
Old 23rd May 2012, 05:09 PM   #411
chinsettawong is offline chinsettawong  Thailand
chinsettawong's Avatar
Originally Posted by mwmkravchenko View Post
Willing to make a set ? You are very good at this and me trying to reproduce it would be quite an effort.
I have amp designs on file already. Would be a most interesting adventure.
A lot of people have been asking me to make the kits, but I just don't have enough time to make them. I'm so sorry.
Wachara C.
Old 23rd May 2012, 05:11 PM   #412
Originally Posted by gentlevoice View Post
Hi again,
Just out of curiosity - any of you made a single-ended headphone, i.e. with only one stator (could be with two stators but only one of them connected to the output signal)? I know that theoretically it's less optimal (due to varying electric fields when the membrane moves, I understand) but any of you tried it in practice? It would allow for a single-ended amp ....
Best regards,
Jesper
Hi Jasper,
Even though I haven't tried it, but I figure that the efficiency will be very low.
Wachara C.
Old 23rd May 2012, 05:11 PM   #413
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Fair enough. If you don't ask you don't get an answer.
Mark
www.kravchenko-audio.com
Old 23rd May 2012, 05:24 PM   #414
gentlevoice is online now gentlevoice  Denmark
Originally Posted by chinsettawong View Post
Hi Jasper,
Wachara C.
Hi Wachara,
Thanks for replying ;-) I'm wondering though - since the membrane is very, very close to the stator I would assume that the drop in the electric field at the place(s) where the membrane moves would be very, very little ... Yet the extra stator adds the double voltage (on the other side of "zero") so might it be that the efficiency loss is 6 dBs (=20*log½)?
Any of you have insights on this?
Greetings,
Jesper
"... It is always possible to be friendly ..." HH the Dalai Lama.
Old 23rd May 2012, 11:45 PM   #415
Someone has done one stator double diaphragms design and feed it with single ended signal. I think it's an interesting design and I might try it in the future.
Wachara C.
Old 19th July 2012, 05:41 PM   #416
Default HE 90 size ...
The driver has the same size as the famous Orpheus HE90. They sound really nice.
Hi again Chinsettawong,
Now I'm in the process of making a model of the stators for an ES headphone and would like to do make like the HE 90 stators you show in #407. You say that the stators you use are the same size as the ones in HE 90 .. Can you say what the dimensions of the active area is?
Greetings,
Jesper M.
Old 21st July 2012, 02:59 PM   #417
Oups .. a comment to #416 ... I would have written Wachara as your name instead of chinsettawong - sorry about that ...
Best regards,
Jesper
Old 21st July 2012, 06:17 PM   #418
The width and height of the stator are 74 cm and 114 cm. The active diaphragm's width and height are 60 cm and 100 cm.
Wachara C.
Old 21st July 2012, 08:08 PM   #419
Thanks Wachara ;-)
I wonder why they've chosen these proportions ... It looks like an ellipse & the proportion between height and width is close to the golden section proportions (1.618) ...
Just pondering.
Best wishes,
Jesper Mønsted
Old 18th September 2012, 04:05 PM   #420
Another pair of headphones is finished. This time I put some engravings on the wood.
Has anybody made an ELS headphone?Hide this!Advertise here!
Never made anything before Moondog55 Chip Amps 5 3rd September 2007 02:45 PM
Where to have PCB's made? mirzametica Parts 5 24th July 2006 06:31 PM
Home Made Tubes?? has anyone made one, is it possible?? John Biles Tubes / Valves 7 11th December 2005 01:29 AM
i made it...!!!!!!!!!!!!!!!!! tbla Everything Else 21 20th December 2002 04:46 PM
