Headphone Systems Everything to do with Headphones
Has anybody made an ELS headphone?
Old 12th March 2012, 03:37 PM   #401
chinsettawong is offline chinsettawong  Thailand
chinsettawong's Avatar
Hi Mark,
I do notice a big increase in sound stage and dynamic from increasing the active diameter from 70 to 80 cm. As far as efficiency, it's not that significantly better.
I'm very interested in your horn loaded ESL. Could you post a link to that, please?
Wachara C.
Old 12th March 2012, 04:02 PM   #402
geraldfryjr is offline geraldfryjr  United States
Yes,I too would be very interested in hearing of your results of a horn loaded Mid/tweet ESL panel.
I truly believe that this could work very well in contrary to others popular belief's.
Cheers !!
jer
Old 12th March 2012, 04:05 PM   #403
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
It's a planar magnetic driver.
ESL is a bit different.
Mark
www.kravchenko-audio.com
Old 12th March 2012, 04:15 PM   #404
Oh,Okay !!! he,he,he
Still would like to hear of your results.
Later this year I will try it though after I get my new little panels built.
Wachara,
I can't believe that it has been a whole year now since I had started my Esl Headphone's and have yet to finish them!!
I think that I will use your method of wood to support the frames now that I have finally gotten my stator coating down pat for the wire mesh stator method.
jer
Old 12th March 2012, 04:23 PM   #405
Mark Kravchenko
ESL has been horn loaded. But true horn loading is not to friendly to an ESL. The one design I will try it the ESL compression driver mentioned. That looks possible.
Mark
Old 12th March 2012, 04:34 PM   #406
I had once thought of using a pair of gold plated CDR's to make a compression type of ESL driver with the exit out of the center spindle holes.
I was thinking of this technique to boost the lower end for a headphone driver as well.
But I have yet to give it a try.
jer
Old 19th May 2012, 02:49 PM   #407
Here is another pair that is almost done:
The driver has the same size as the famous Orpheus HE90. They sound really nice.
Old 19th May 2012, 03:55 PM   #408
gentlevoice is offline gentlevoice  Denmark
Originally Posted by Nixon View Post
Read this and the similar thread over at DIY Audio and I think I might have to have a crack at a set. Spent the evening on Sketchup and have began designing the stator and spacer.
Ever so slightly ripped off from one of chinsettawong's designs. Do they seem ok so far? They're both 90mm in diameter so you have an idea of scale.
Hi - sounds interesting that you are using sketchup for this. Any chance you can post some pictures of your drawings? And also which file format do you output from Sketchup? I'm interested in drawing headphones myself, however, probably would need an .stl output format - for use with a 3D printer.
Greetings,
Jesper
"... It is always possible to be friendly ..." HH the Dalai Lama.
Old 21st May 2012, 06:00 PM   #409
Mark Kravchenko
Willing to make a set ? You are very good at this and me trying to reproduce it would be quite an effort.
I have amp designs on file already. Would be a most interesting adventure.
Mark
Old 23rd May 2012, 04:47 PM   #410
Hi again,
Just out of curiosity - any of you made a single-ended headphone, i.e. with only one stator (could be with two stators but only one of them connected to the output signal)? I know that theoretically it's less optimal (due to varying electric fields when the membrane moves, I understand) but any of you tried it in practice? It would allow for a single-ended amp ....
Best regards,
Jesper
Has anybody made an ELS headphone?Hide this!Advertise here!
Never made anything before Moondog55 Chip Amps 5 3rd September 2007 02:45 PM
Where to have PCB's made? mirzametica Parts 5 24th July 2006 06:31 PM
Home Made Tubes?? has anyone made one, is it possible?? John Biles Tubes / Valves 7 11th December 2005 01:29 AM
i made it...!!!!!!!!!!!!!!!!! tbla Everything Else 21 20th December 2002 04:46 PM
Copyright ©1999-2017 diyAudio
