Headphone Systems Everything to do with Headphones
Has anybody made an ELS headphone?
Old 12th January 2011, 11:27 AM   #321
chinsettawong is offline chinsettawong  Thailand
chinsettawong's Avatar
Hi JonusKarud,
The design you pointed to was actually what I had in mind. If I were to use a double sided PCB in the middle, then I only need 3 pieces of stators to work with a double diaphragms design. I can do that easily. I agree with you that it will take some experiments to actually find out if the theory works. I will find the time to experiment with this design.
Wachara C.
Old 12th January 2011, 11:29 AM   #322
Hi Calvin,
Your description of 3-layer sandwich-membrane confuses me. I can't get a clear picture in my head. Can you please elaborate?
Wachara C.
Old 12th January 2011, 01:25 PM   #323
JonasKarud is offline JonasKarud  Sweden
JonasKarud's Avatar
Hi Wachara,
if you´re going to try the three stator design, theres a whole bunch of things you can experiment with! For example, connect the outer stator to ground via a 47-200k resistor so that the outer membrane is low pass limited to 1000 Hz. You can also try to give the two membranes slightly different mounting tensions, as I had better (cleaner and tighter) sound when I did this in my experiments.
Now I'm so inspired I must take up my experiments again! I'm thinking of something like a double membrane wire stator Jecklin Float EarSpeaker!
Reality is just a word....
Old 12th January 2011, 02:08 PM   #324
Hi JonasKarud,
Thanks for your suggestion. Let me design the middle stator, cut the parts, and let's have some fun.
Wachara C.
Old 12th January 2011, 02:19 PM   #325
Calvin is offline Calvin  Germany
Calvin's Avatar
the 3-layer membrane would yield two layers of film and a layer of conductive adhesive in between. Think of a double sided PCB, where the two copper surfaces represent the film and the core material (FR4 or alike) represents the conductive adhesive.
The two film layers would shield the core layer against environmental influences like humiduity or sratch resistance. Leakage could be reduced, since there´d always be an insulating layer between the conductive core and the outside world. The films would also function as an additional insulating layer which allows for an increased flashover treshold.
Though beeing very thin films the flashover treshold of the film could reach a couple hundred volts.
So its a totally different thing as a 3-stator-ESL.
A different tension of the films is not needed. The close mechanical coupling of the two membranes lead to a beghaviour as if it were just one membrane. So the mechanical tension ofthe films is connected in series, which leads to a reduced overall tension, hence lower Fs. Since the Fs of HPs easily ranges around 100Hz the reduction in Fs may well be responsible for the improved bass response.
This is simialar to the Fs reduction caused by the increased weight of a 3-layer membrane.
jauu
Calvin
Old 12th January 2011, 02:25 PM   #326
Hmm. That would be extremely difficult to DIY.
Wachara C.
Old 12th January 2011, 02:52 PM   #327
alexberg is offline alexberg
alexberg's Avatar
I believe there was (is) a company, using twin membrane in inverted ESL i.e. one film metallized, one plain, with the coating in between.
Old 13th January 2011, 09:29 AM   #328
Calvin's Avatar
afaik Audiostatic claimed to have used a compound diaphragm in their1990ies decade models.
jauu
Calvin
Old 14th January 2011, 03:48 AM   #329
I still can't figure out how a sandwiched diaphragm would outperform a single layer. When you glue them together, they become one. So what's the difference compared with a thicker Mylar. I understand that by sandwiching, you get a better weather shield. But for sound, I really doubt it.
However, with a triple stators and 2 diaphragms design, I think it can improve the sound pressure. It will probably make the sound louder and bass deeper. Don't you think?
Wachara C.
Old 14th January 2011, 08:06 AM   #330
Calvin's Avatar
there are several, methods to improve bass response. One of which is to use a heavier and thicker membrane. This is what Stax has done with the C32. They could have achieved the same result with a coated and equally thick mono-membrane. But besides the acoustic response, safety and longevity aspects have to be dealt with and may have been the decisive points to choose the sandwich membrane over a mono-membrane.
2nd answer is yes.
jauu
Calvin
Has anybody made an ELS headphone?Hide this!Advertise here!
Never made anything before Moondog55 Chip Amps 5 3rd September 2007 03:45 PM
Where to have PCB's made? mirzametica Parts 5 24th July 2006 07:31 PM
Home Made Tubes?? has anyone made one, is it possible?? John Biles Tubes / Valves 7 11th December 2005 02:29 AM
i made it...!!!!!!!!!!!!!!!!! tbla Everything Else 21 20th December 2002 05:46 PM
Copyright ©1999-2017 diyAudio
