Headphone Systems Everything to do with Headphones
Has anybody made an ELS headphone?
Old 5th November 2008, 04:21 PM   #11
chinsettawong is offline chinsettawong  Thailand
chinsettawong's Avatar
Michael,
Thanks for your info. I do not have a signal generator and I do not understand its usage. Could you kindly explain to me what to look for when you make a measurement using a signal generator?
The diaphragm I use is actually the plastic wrap that you wrap on your food when you microwave. I do not know its thickness, but it is very thin. The thinnest I can find around here.
Wachara C.
Old 5th November 2008, 05:23 PM   #12
frank ziel is offline frank ziel  Germany
go to a TV repairman and ask him to tell you the step up rate.
Where did you get the transformer from?
It all sounds to me, that the bais is way too high and has sucked
the diaphragm into the statorplate. This happened when I build
a headphone 33 jears ago, not enough stretched the thing,
because I wanted bass. You also should support the membrane
in the center to both sides with silicone dots.
There was a nice DIY headphone design in the
GB mag "Wireless World" Nov. 1979, which I can send you by email,
because it is to lage for an attachment here.
Frank
PS: Your headphone looks a lot nicer than mine looked!
Very nice!
Old 5th November 2008, 05:56 PM   #13
Steerpike is offline Steerpike
Steerpike's Avatar
Default Andrew radford has done it
I found this web page by Andrew Radford a few months ago - it looks informative, and I was going to copy his example.
http://www.headwize.com/projects/sho...dford1_prj.htm
Old 6th November 2008, 06:24 AM   #14
Frank
Very nice!
Thank you very much for your info. I'll check if the diaphragm is ok.
I'm very interested in the magazine. I'll send you an email.
Old 6th November 2008, 06:32 AM   #15
Default Re: Andrew radford has done it
That's exactly where I get my design from.
Wachara C.
Old 6th November 2008, 07:10 AM   #16
Calvin is offline Calvin  Germany
Calvin's Avatar
the 0.4mm of d/s should be fine to get earsplitting levels. Especially so with nearly unbelievable high polarizing voltage of 1.2kV. Commercial Designs like the Stax et al usually work with less than 600V! 1200V canīt be the real value, because itīs way above the arcing limit of air anyway. So I assume that the īrealī polarizing voltage will be just around 500-700V or even less.
The soft sound may come from the membrane material. Even though it looks very thin, itīll be too thick for ESL usage. The thinnest film I can get here in a supermarket is 18ĩm thick, which is too much and too heavy to reach complete audio bandwidth (freq-response will probabely start to drop above 5-10kHz. For Headphones You need the thinnest possible material, if possible below 2.5ĩm.
Liquid soap is a quite good membrane coating.....for maybe a week.
You should use a more stable material which adds less mass too, e.g the glue-formula (search the forum for membrane coating)
The last point regards the used transformer. When it shows high leakage inductance values the bandwidth of the system Panel/Transformer will resonate below 20kHz, thereby limiting the bandwidth to values below 20kHz.
jauu
Calvin
Old 6th November 2008, 07:23 AM   #17
Calvin's Avatar
Iīve just taken a closer look at your pics. Am I right in that You use some kind of PCB-like material with the statorīs conductive side to the outside?
If so, Your d/s will not be 0.4mm but 0.4mm+ thickness of the stator insulation. If for example You use normal 1.5mm FR4, Your d/s would be 1.9mm. Than 1.200kV of polarizing voltage would not only be allowed for the headphones not to arc, but it would actually be quite a bit low. The problem with this large d/s is now that the capacitance of the headphone drops to very small values. A small capacitance means high impedance values. So Youīd need a transformer with a very high transformation factor. Otherwise the impedance mismatch between driving amp and load would be too great, hence the headphone would play at only very low levels.
A last remark. If the holes in the stator are small and the stator is relatively thick, the holes start acting like a Bassreflex-channel! The bandwidth of the sum of the channels can easily drop below 20kHz.
So even if everything else is alright, the dimensions, shape and number of holes in the stator could ruin a good result.
jauu
Calvin
Old 6th November 2008, 01:59 PM   #18
Dear Calvin,
Thanks for your input.
Yes, I use 1 mm PCB material as the stators. I cut them using my DIY cnc machine. I put the copper side inside and with a plastic spacer then a piece of diaphragm, spacer, and PCB with the copper side facing the diaphragm. So the thicknesses are 1 mm, 0.5 mm, diaphragm (thickness?), 0.5 mm, and 1 mm respectively.
The holes are 2 mm. I didn't know the shape and stator holes play a so important role. Could you please let me know what the ideal shape and dimension of the holes should be?
I played with a different diaphragm and spacer today. Interestingly, I found the sound from thicker spacers (1mm) and somewhat thicker diaphragm actually was louder with the same level of bias voltage and input volume compared to the previous one. My guess was that my old one had actually a problem with diaphragm arching to either side of the stator. I am going to use this same diaphragm with the 0.4 mm spacer to see what will happen. Will keep you inform.
Wachara C.
Old 6th November 2008, 03:27 PM   #19
atarashi is offline atarashi  Austria
ok, so d/s spacing is only 0.5mm, but then the polarisation voltage is to high.
could you lower it, maybe down to around 500-600volts?
michael
Old 7th November 2008, 12:28 PM   #20
Michael,
I'll try to lower the bias voltage.
Wachara C.
Has anybody made an ELS headphone?Hide this!Advertise here!
Never made anything before Moondog55 Chip Amps 5 3rd September 2007 03:45 PM
Where to have PCB's made? mirzametica Parts 5 24th July 2006 07:31 PM
Home Made Tubes?? has anyone made one, is it possible?? John Biles Tubes / Valves 7 11th December 2005 02:29 AM
i made it...!!!!!!!!!!!!!!!!! tbla Everything Else 21 20th December 2002 05:46 PM
