Headphone Systems Everything to do with Headphones
12 Volt MOSFET SE Class A Hi-Fi HeadPhone Amp
Old 16th July 2008, 10:26 AM   #1
lineup is offline lineup  Sweden
lineup's Avatar
Cool 12 Volt MOSFET SE Class A Hi-Fi HeadPhone Amp
Good hifi
Intended for High Fidelity 32 Ohms Headphones.
- 12 Volt DC, preferably regulated 78M12 or LM317
- 2N3819 JFET high impedance input
- ZVP3306A, TO-92 PMOS, VAS Voltage amp stage
- IRF610 Single End 125 mA Class A output
- Internal Bandwidth is 8 MHz ( Closed Loop without RF input filter )
- Gain +10 dB ( x3.1 )
- Distortion in 32 Ohm/1 mW is below -100 dB, 0.001%
I attach my simplified concept diagram.
If anyone wants, I post my full, tweaked and optimized working simulated tested circuit.
Lineup Audio
lineup
Old 16th July 2008, 12:21 PM   #2
lineup's Avatar
hi
If you use for example Grado Hi-Fi Headphones 32 Ohm
http://www.gradolabs.com/
you have a specification: Sensitivity, SPL at 1 mWatt = XX dB
This means, at 1 mW you will have Sound Pressure Level of XX dB in your ears.
Say we have headphones with SPL = 98 dB / 1 mW
At 10 mWatt we will have another +10 dB
Which in this case give a sound pressure of 108 dB ... !!!
... dangerous, yes .. I have tinitus .. a damage caused by headphones
... be very careful, my friends
I attach the very nice Fourier spectrum of this Class A MOSFET amplifier.
In fact the harmonics are like this at any output level .. until overdriven/clipping.
FFT at 10 milliWatt, +10 dB
lineup
Old 16th July 2008, 12:41 PM   #3
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Default Re: 12 Volt MOSFET SE Class A Hi-Fi HeadPhone Amp
Lineup Audio
Very nice! Give us the full thing! We like.
Old 18th July 2008, 01:49 AM   #4
d to the g is offline d to the g  United States
d to the g's Avatar
2nd.
motion passes, gives us the precious schematic.
12 Volt MOSFET SE Class A Hi-Fi HeadPhone AmpHide this!Advertise here!
MOSFET follower headphone amplifier GRollins Headphone Systems 187 2nd May 2017 01:26 AM
headphone amplifier = tube + mosfet sparkle Headphone Systems 25 23rd June 2009 02:52 PM
Fault with MOSFET based headphone amp zebra100 Headphone Systems 8 7th October 2008 03:29 PM
Regulated PSU for MOSFET headphone amp zebra100 Headphone Systems 9 25th September 2008 05:59 PM
