Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 30th June 2008, 03:38 PM   #1
Inocybe is offline Inocybe  Norway
Question Portable headphone amplifier project!
I would like to make a portable headphone amplifier.
The thing that would seperate this from other headphone amps is that it would be much smaller. It may not have the power to drive large (high Ohm) headphones, but enough to drive smaller ones loud and with control.
Why? The amps in many portable electronics is often very poor and weak (notebooks, mobiles, mp3-players ++).
This is the features that I want it to have:
- 3.5mm in stereo plug (with short chord)
- 3.5mm out stereo jack (internal)
- Quality 1.5V stereo up-amp producing high output (20mW/32Ohm+?)
- On/off switch
- Led (power on)
- Power source: 1 x AA
- Small case
If possible:
- Volume control (could be in steps)
- 5/7/10 Band EQ or other kind of adjustable tone control
My idea was to have it totally analogue (digital would be more difficult, I guess). No splitter to save battery (just one jack).
The volume should mainly be adjusted with the source device, but there should (maybe) be a possability to adjust the volume on the amplifier also. This because of adjusting it to the source volume and/or save battery. The goel is to limit the source volume just beneath clipping/distortion/loss-of-control point.
It would be great if a EQ or adjustable tonecontrol could be included. Many devices have no adjustable EQ, or it is quite bad. The source device could then be set in a "flat" position.
The casing should be small enough to be hanging loose, just connected to the jack and plug. With two AA batteries, it suddenly becomes more heavy.
Is it possible to run it on a single AA battery? I have an old iRiver iFP-799 MP3-player with quite good soundquality and with a good amplifier (2x18mW/16 Ohm). The single AA battery last 40 hours. It also uses power on the screen and other things(!). So yes, I think it would be quite possible.
Here is a commersial headphone amp manufacturar:
http://www.boostaroo.com/
They have splitters, making them use more power. They use two AA batteries (heavy) or two AAAA batteries (unpractical). Also, no volume or tone controls.
Please note that I am an electronic novice! I would be happy to get any feedback on this (like part suggestions). So, what do you think?
Old 5th July 2008, 06:34 PM   #2
TerryO is offline TerryO  United States
TerryO's Avatar
Default Re: Portable headphone amplifier project!
- On/off switch
- Led (power on)
- Small case
If possible:
Ino,
Here's what you should start with:
http://headwize.com/ubb/forumdisplay.php?fnum=3
Great forum as well.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 6th July 2008, 08:11 AM   #3
Nordic is offline Nordic  South Africa
Nordic's Avatar
Mini Ipod headphone amp DIY project
Another Class A headphone amplifier project. Dxvideo Headphone Systems 5 26th September 2008 07:27 AM
Project No. 1: Beta22 Headphone Amplifier steaxauce Headphone Systems 0 3rd April 2008 09:12 PM
Portable headphone amp. cliffforrest Headphone Systems 4 27th January 2007 02:15 PM
Mini Portable Headphone Amplifier, with Discrete Diamond Buffers cetoole Headphone Systems 3 30th May 2006 06:32 AM
Page generated in 0.11012 seconds (74.43% PHP - 25.57% MySQL) with 10 queries
