Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 14th March 2003, 05:58 PM   #1
Default sym. Headphone amp
please comment this headphone amp.
Is it working in X- mode?
I`m using it with separated grounds via a
5 pole Neutrik plug. I think it sounds pretty
good. The powermosfet have some headsinking
and are joint together. Diffpair glued. All
fets are paired. When i can take a cam i will
post some pics.
Bye everybody, Andreas
Old 15th March 2003, 06:35 AM   #2
Default Pics
Sorry for the low res pics.
Headphone is 150 Ohm Sennheiser.
And please not so many comments;-)
Andreas
Old 15th March 2003, 06:36 AM   #3
Default pic nr. 2
pic nr. 2
Old 15th March 2003, 10:42 AM   #4
Circlotron's Avatar
Default Re: sym. Headphone amp
I say YES.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 15th March 2003, 05:02 PM   #5
thanks for the reply circlotron.
Andreas
Old 15th March 2003, 06:42 PM   #6
paulb is offline paulb  Canada
Andreas, did you modify the headphone cable? Or did it come with a balanced connector?
Old 15th March 2003, 06:49 PM   #7
The one and only
Nelson Pass's Avatar
It's an X, and a fine looking one.
Old 15th March 2003, 07:28 PM   #8
Thanks Nelson
to paulb: Yes i cut the standard plug
and separate the grounds. The 5 pin Neutrik plug
looks good also and is really good quality.
Andreas
Another DAC + Headphone amp ghetto Digital Source 14 10th July 2008 04:02 PM
Using a headphone amp as a pre-amp? Basalt Solid State 4 19th November 2007 09:55 AM
ESL Headphone X-former bjackson Planars & Exotics 5 19th September 2005 03:45 AM
Headphone amp audioPT Headphone Systems 3 20th September 2004 10:17 PM
Zen v4 headphone amp Rob M Headphone Systems 11 21st May 2003 12:58 AM
Page generated in 0.08520 seconds (78.58% PHP - 21.42% MySQL) with 11 queries
