low voltage headphone amp - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 23rd May 2008, 07:41 AM   #11
Mooly's Avatar
There is a TDAxxxx I/C for this very use, and I can't remember the number !
Old 23rd May 2008, 12:04 PM   #12
Mooly's Avatar
It's the TDA7050, this is as simple as it gets, works down to 1.6 volts as well. You need series resistors to the 'phones if you use this.
Old 24th May 2008, 08:00 AM   #13
Dan2 is offline Dan2  South Africa
well all i could get are LA4570 chips. i have not checked the datasheet for them yet but they should work.
Old 24th May 2008, 08:09 AM   #14
Mooly's Avatar
Have you a circuit to use one of these. These are a dual pre and power in one package I think.
Old 24th May 2008, 10:28 AM   #15
lineup is offline lineup  Sweden
lineup's Avatar
Default Re: low voltage headphone amp
Originally posted by Dan2
what i really want to do is build it so it can
get its power from one of the usb plugs on the xbox,
so no batteries will be required.
i also want it to sound quite decent
- as i am sure the usb has enough power to do (i think usb has 5v, 200mA output???)
i was thinking of using an opamp, but if you have a better idea please share.
One thing you may want to checkout, is how much 'PC-noise' is on USB power jacks.
Computer circuits generate a lot of noise. From high frequencies and also lower.
Any audio amplifier benefits from a CLEAN Supply.
For example those PC speakers we use, mostly use OWN Power supply adaptor.
You may have to filter the USB power a bit. Using some capacitor/resistor.
I am sure you can use USB, as you only need a few Volts to get enough power.
I guess we are talking 16 / 32 Ohm freestyle or light type of headphones.
The sensitivity of such can be very high: 100-105 dB per mW is not unusual.
And they can be powered good from only 2 x 1.5V batteries. = 3.0 Volt supply.
If you could find Specifications on headphones in question
it would be a good help for advice you.
As AndrewT has mentioned, there are 2 things we would want to know:
- 1. Impedance, in Ohm. Can be 16, 32
(Some modern hifi big headphones has got 150, 300, 600 Ohm impedance)
- 2. Sensitivity. In dB SPL = Sound Pressure Level
Usually how loud in dB at 1 mW input power.
Regards, Lineup
fotenote:
There is new standard for sensitivity, used by e.g. Sennheiser.
SPL at 1 Volt RMS.
See my attachment:
Specifications for Sennheiser HD 650 ( Top of the line expensive HeadPhones)
Nominal impedance .................................................. ............... 300 Ω
Sound pressure level................................115 dB (at 1 kHz, 1 Vrms)
lineup
Old 24th May 2008, 12:48 PM   #16
i didn't even think of noise on a usb power supply!! i will have to check that out.
as for the headphones - well - i want it to be able to run with any type as i may be building a couple for other guys. i seriosly doubt any of them will have top of the range type headphones. for example, the headphones i am building this circuit for are (almost) bottom of the range - the type that has vibration bass (little motors that shake with the bass) and although quality is ok, its not anywhere near the quality of expensive headphones.
Old 24th May 2008, 09:56 PM   #17
nelsonvandal's Avatar
If you care about sound quality, why not just steal others success? I think the very well renowned portable headphone amp Xin Reference use AD8615 as L/R amps and AD8531 as ground channel amp. They are specified for 2.7 - 6 V supply and are good for 150/250 mA output current. AD8397 is also a very popular opamp for headphones, 3 - 24 V supply, 310 mA peak output current.
For your convenience, use a board from Mini3, or why not the whole amp, it uses the AD8397 mentioned above for left/right and OPA690 for ground (specified for 4.5 - 12 V supply and can deliver plenty of current):
http://www.amb.org/audio/mini3/
This is a true hifi headphone amp. You can even buy complete kits from
http://www.glassjaraudio.com/main.sc
If you have "normal" = lowish impedance headphones, you don't have to worry about not having enough sound pressure. 1 V into phones like this is very loud, 5 V is crazy. It's simply not true that monolithic opamps can't drive headphones.
Old 25th May 2008, 08:35 AM   #18
well i already got these LA 4570 chips - but i cant find the datasheet for them!!! i will keep on looking.....
Old 25th May 2008, 09:17 AM   #19
lineup's Avatar
Hard to find a datasheet.
Here is a Romanian schematic, with data on LA4570.
Max voltage is 4.5 Volt. And typically it is used with 3 Volt DC.
This means 2 x 1.5 Volt battery.
2 x 0.02 Watt = 20 mW is more than you probably ever need.
We can also see a bit about the PIN configuration and figure out howto use it:
From this page:
http://www.electronica.ro/audio/LA4570.shtml
Sanyo LA4571 may be a very similar headphone IC.
Here is one link to this PDF:
http://www.ddrservice.net/66c507f/In.../la/la4571.pdf
Regards, Lineup
lineup
Old 25th May 2008, 02:55 PM   #20
thanks for finding that!!
just to double check - the odd looking symbol on pin 2 and 15 is the inputs??? and the 10k variable pots are the volume control (or gain?)??
if i use a usb and just run a diode in series that should give me the right voltage (or even a 3v regulator - that should help with the noise)
Headphone Line-Out Voltages - (Newbie DMM AC Voltage Reading) trelin Headphone Systems 7 9th May 2008 08:15 AM
Rail Voltage to Capacitor Voltage Mermprin Parts 6 20th September 2004 04:56 PM
Opinions on my low-voltage hybrid headphone amp (this time with the right file) JHawk24821 Headphone Systems 2 1st August 2004 05:49 PM
Rail voltage compared to transformer voltage SteveG Solid State 4 23rd July 2002 12:50 AM
Copyright 1999-2017 diyAudio
