Sugestens on improving my this headphone Amp - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 14th March 2003, 10:30 PM   #11
ppl is offline ppl  United States
ppl's Avatar
peranders. that was the concensious of myself also
Old 29th July 2003, 10:59 AM   #12
ppl's Avatar
This is the Compleated Amp so far almost done. I have decided upon a set of (4) Buffers as the THD went down with each Buffer addition with 2 volts RMS into 32 ohm Resistive loads.
The Results of using 1/2/3/4 Buffers per Ch
@ 1KHz> (1) Buffer (2) Buffers (3) Buffers (4) Buffers
THD, %: 0.051 / 0.025 / 0.014 / 0.0084
IMD, %: 0.045 / 0.024 / 0.020 / 0.019
The Op-Amps used in the Above are the AD-8610AR
The Sound is fantastic with the halmark of this Amp Being soundstage. since i got such great imaging with Headphones I thought some low volume listening with Gasp! a pair of small loudspeakers (Radio Shack Pro77 Metal box type) were in order and what a great treat that was with some parts coming from below the Floor. Most Loudspeaker Amps will not do that with alot more costly loudspeakers. Overall I am happy with the Measured and sonic performance of this Amp. BTW this version uses OPA-637 in gain channels and OPA-627 in the Ground Driver Channel.
Inside Photo
Old 31st July 2003, 04:11 AM   #13
Send a message via AIM to Systempimp_1500 Send a message via MSN to Systempimp_1500
anyone noticed how much adires preamps cost?
$2800........ouch.....
Jeff
improving diy loudspeaker milen007 Multi-Way 16 28th April 2009 10:36 AM
Improving DC-servos Elvee Solid State 22 16th September 2008 11:04 AM
Help me improving my pre-amp! thanh Solid State 0 26th January 2007 10:08 AM
improving my VAS djdamix Solid State 27 13th February 2005 12:54 PM
Improving the Futterman Sch3mat1c Tubes / Valves 6 18th August 2003 10:35 PM
Copyright 1999-2017 diyAudio
